| Re: Self Build / Barn Conversion question?
depends where you want it in Kent, there's alot of green belt and restricted land, and in commuter belt range it gets very expensive
where I live a plot with planning for a small 3 bed detached and garage would cost you 150-200k for the land, in chatam 20k
getting a mortgage at the moment I would imagine to be very hard and expensive for this type of project since the only asset is the land, budget 20% for the unexpected.
houses have to come up to building regs, one of the regs covers thermal efficiency, glass walls have crap thermal efficiency so you normally have to over compensate on the floors, roofs, other walls (smaller windows) etc
watch the construction type, mortgage lenders in the uk dont like timber frame buildings so it can make selling them harder, traditional brick and pitched roofs houses are fast to build. The construction firm I worked for had a property arm and we used to build housed in 8 weeks from digging footings to final fix.
there are two big areas which are a money sink for house building, the external materials and the internal fittings, there's no point spending £1500 a thousand for hand made bricks when you can get a mass produced equivalent for a fraction of the cost when 99% of people cant tell the difference. Its also easy to blow fortunes going mad on kitchen, bathroom and wood finishings.
don't over customise it, there's not point spending 400k on a place that's your dream house only to make it unsellable.
