Quick heating question
Old 27-08-2009, 2:02 PM   #1
KhalJimbo's Avatar
20,437, Level: 34
Points: 20,437, Level: 34 Points: 20,437, Level: 34 Points: 20,437, Level: 34
Activity: 15.9%
Activity: 15.9% Activity: 15.9% Activity: 15.9%
Thanks: Gave 1,009, Got 603
Hi All
I have just ordered some underfloot heating for my renovation project, but I also want to get a gas fire on the wall and have a rug underneath or something (basically a little reading place) but wanted to know how possible this is going to be, I have a conventional radiator on the wall (a water one I guess) but I want to replace it with a wall mounted gas fire, how possible is this, is it just a matter of getting a gas man in to swap a few pipes around by the boiler or is it alot more complex than that?
I'm not to familiar with how heating systems work, I'm from south africa so our heating system is using an extra blanket about 1 month of the year
thanks for any help
Old 27-08-2009, 2:07 PM   #2
Phil57's Avatar
3,207, Level: 13
Points: 3,207, Level: 13 Points: 3,207, Level: 13 Points: 3,207, Level: 13
Thanks: Gave 600, Got 310
Re: Quick heating question
I am not a 'gas man.'
The answer to the question 'is it more complicated than that' is yes it is.
Is the wall that you intend to use, an exterior wall?
Old 27-08-2009, 2:11 PM   #3
KhalJimbo's Avatar
20,437, Level: 34
Activity: 15.9%
If you mean is there grass on the other side and not another room then yes
Old 27-08-2009, 3:24 PM   #4
7,549, Level: 20
Points: 7,549, Level: 20 Points: 7,549, Level: 20 Points: 7,549, Level: 20
Thanks: Gave 69, Got 273
A conventional radiator has 2 water pipes (1 in and 1 out) which go to the boiler. The boiler heats the water which circulates through the radiator. The radiator can be removed and these pipes capped off.
A gas fire needs a gas supply which will probably be the hardest thing to do. Somehow, a pipe needs to be run from the gas main inside the house to where the fire is going to be. Then there is the question of getting rid of the combustion gases. If the fire is going on an outside wall, then some sort of flu is an option. I believe there are also gas fires which can be installed pretty well anywhere and use some sort a catalytic reaction to neutralise the combustion gases. I've seen them on boats anyway.
KhalJimbo (27-08-2009)
Old 27-08-2009, 4:28 PM   #5
KhalJimbo's Avatar
20,437, Level: 34
Activity: 15.9%
hmmm, that could be quite costly I might just have to get an electric one but I like the idea of having a fluless wall mounted fire to site and read infront of
Old 27-08-2009, 4:40 PM   #6
IronGiant's Avatar
25,192, Level: 38
Points: 25,192, Level: 38 Points: 25,192, Level: 38 Points: 25,192, Level: 38
Activity: 28.7%
Activity: 28.7% Activity: 28.7% Activity: 28.7%
Thanks: Gave 2,341, Got 4,989
Have you considered something like this that runs from a self contained gas bottle:
Provence Living Flame Portable Heater
Bottled gas is obviously much more expensive to use than mains but if it's for occassional use only is an option...
You can also get wall mounted fires that you can supply from bottled gas stored outside just the other side of the wall requiring a single hole for the gas pipe if flueless or can have a flue going through the wall, but these would have to be professionally fitted so you may as well get the mains gas plumbed through...
Dave
