Originally Posted by rich_d8 This is probably going to sound really stupid, but i have just moved into a flat with 2 dimplex storage heater (Model number CXL24N) and i was just wondering how they work.
I understand that they only come on overnight as they are connected to a different circuit but do they stay on full the full 7 hours of economy 7 or do they turn off when they are fully charged ?
I am trying to estimate how much it is going to cost me to use them. Does anyone else have Dimplex storage heaters and knows for example how many hours are needed to reach full charge, medium or low charge.
Any help is greatly appreciated. |
Storage heaters rely on the fact that some electricity tariffs charge lower rates at certain times in the day
If you contact the electricity company that supplies the juice for your flat they will tell you the tariff that you will currently be charged. You may find cheaper by using a comparison site.
Basically, most "economy 7" or "dual tariff" electricity prices provide a daytime rate and a reduced price nightime rate. The lower rate operates, usually, for 7 or 8 hours overnight and is usually around half the price of daytime. Storage heaters use this reduced price electricity by charging at night and gradually releasing the heat during the day to provide heat over 24 hours
A storage heater is basically a pile of heavy bricks surrounded by elements like those in a cooker grill and high quality insulation. When the time switch turns them on, the elements get hot and warm the bricks to very hot. The insulation keeps the heat in the bricks and the whole thing gets warm and releases heat during the day
A variety of controls allows you to adjust the amount of electricity going in and control the heat coming out. In periods when it is cool rather than cold, you can set the input at low. When it's brass monkeys outside, you can turn the input up to max
If you are out all day you can usually close a regulator to slow the rate that heat escapes allowing you to open the regulator later in the day when you want the heat
Some electricty suppliers arrange for a "boost" or further charge, later in the day, so that evening performance is better
Storage heaters are a good idea if your flat is well insulated and you do not have an open fire, which extracts heat as the air is drawn up the chimney
To answer the specific question you ask, they will stay "on", drawing charge, for the full period of the reduced period electricity (you can probably see what this is by looking at the time clock where the electric meter is), but they will cycle on and off, like an electric cooker thermostat works, according to the setting of the input dial that you control. These are usually 1 to 6. 1 will give barely warm (inexpensive) and 6 will be s..t hot (bit more, but still probably ok)
The dimplex web site will give you information about the specific models you have
Incidentally it is usually the case that any other electricity use such as immersion heater for hot water as well as the washing machine and other high energy items will benefit from this cheaper electricity which can extend in some areas to 8am gmt
