13-08-2009, 4:15 PM
#1 (permalink)
| | Veteran Member
Thanks: Gave 1,013, Got 1,272 | Attaching stainless steel splashbacks onto tile...
Just bought a couple of splashbacks for behind the hob and the sink - the manufacturer says just use no more nails type adhesive to fix it onto wall. Is it ok to do this on top of existing tiles?
Matt Panasonic TH42PX70; Onkyo TX-SR606; Mordaunt Short Genies 6.1; SkyHD; PS3 Slim 120GB; PSN: Woodywizz
13-08-2009, 4:20 PM
#2 (permalink)
| | Moderator
Thanks: Gave 583, Got 1,555 | Re: Attaching stainless steel splashbacks onto tile...
Should be fine so long as they are completely grease free. Give them a good clean with your favourite kitchen cleaner then a wipe over with some white spirit or your best malt whisky depending on which one you prefer the smell of
Dave
We all stand on the shoulders of giants... My personal opinion is not necessarily AVF policy.
13-08-2009, 5:45 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 236, Got 148 | Re: Attaching stainless steel splashbacks onto tile...
Might be worthwhile brushing some Unibond on the tiles too.
13-08-2009, 5:52 PM
#4 (permalink)
| | Veteran Member
Thanks: Gave 1,013, Got 1,272 | Re: Attaching stainless steel splashbacks onto tile... Quote:
Originally Posted by Johnny Thunder Might be worthwhile brushing some Unibond on the tiles too. | Do you mean this - CLICKY
13-08-2009, 5:57 PM
#5 (permalink)
| | Member
Thanks: Gave 12, Got 46 | Re: Attaching stainless steel splashbacks onto tile...
Just blob silicon sealant on the back of it and press it on - that'll do it.
13-08-2009, 5:58 PM
#6 (permalink)
| | Moderator
I think Johnny means Unibond PVA...
Silicon sealant gets my vote too...
Dave
13-08-2009, 6:24 PM
#7 (permalink)
| | Member
Join Date: Feb 2002 Location: Sunny Ilson, pride of Derbyshire!
Thanks: Gave 102, Got 105 | Re: Attaching stainless steel splashbacks onto tile...
This stuff will work. There are probably cheaper, but someone gave me a spare tube of this, and I used it to stick Stainless Steel things up in the bathroom, onto tiles, and they're still there. Click Me
Can't believe a company like Evo chose that name though
"My own type of communism's fine."
13-08-2009, 6:39 PM
#8 (permalink)
| | Moderator
I've just got to buy some just to have it in the cupboard
Woody, you have your winner
13-08-2009, 6:56 PM
#9 (permalink)
| | Member
Join Date: Dec 2003 Location: The Credit Stretch (Olympics 2012 Site, London)
Thanks: Gave 70, Got 27 | Re: Attaching stainless steel splashbacks onto tile...
Grip-fil attaches anything to anything. Just don't get it on yer hands...
__________________ Ex-Sunnyvale Amdahl Dinosaur |
13-08-2009, 10:12 PM
#10 (permalink)
| | Member
Thanks: Gave 141, Got 346 | Re: Attaching stainless steel splashbacks onto tile...
My dad has a company doing stuff in stainless steel (inlcuding splash backs for high end kitchens) and when he fixed some in our house (directly to the wall rather than tiles) he used some 3M double sided tape that will take the wall down rather than become unstuck (or so he said  )
Unfortunately I don't remember exactly which model it is and it's too late to ask my dad but you could look into it.
13-08-2009, 10:44 PM
#11 (permalink)
| | Member
Thanks: Gave 374, Got 230 | Re: Attaching stainless steel splashbacks onto tile... Quote:
Originally Posted by Woodywizz Just bought a couple of splashbacks for behind the hob and the sink - the manufacturer says just use no more nails type adhesive to fix it onto wall. Is it ok to do this on top of existing tiles? | Out of interest where did you get your SS splashbacks from!
__________________ "Hey,what happened to Progressive Ed?" XBOX Live-ADT65 WARNING! Disabled access is a Dalek conspiracy! |
13-08-2009, 10:47 PM
#12 (permalink)
| | Veteran Member
Originally Posted by Bill Hicks Out of interest where did you get your SS splashbacks from!  | Ebay - just do a search on stainless steel splashbacks, there are loads.
13-08-2009, 11:56 PM
#13 (permalink)
| | Senior Member
Thanks: Gave 436, Got 474 | Re: Attaching stainless steel splashbacks onto tile... Quote:
Originally Posted by Bill Hicks Out of interest where did you get your SS splashbacks from!  | I got mine recently from a local engineers who cut it to size for me. I fixed it to the wall directly using Grip-Fill.
__________________ Sshhhhh Now |
14-08-2009, 10:24 PM
#14 (permalink)
| | Veteran Member
Originally Posted by Dony I got mine recently from a local engineers who cut it to size for me. I fixed it to the wall directly using Grip-Fill. | Do you just put a few random blobs in the corners and middle, and then press??
14-08-2009, 10:29 PM
#15 (permalink)
| | Senior Member
Originally Posted by Woodywizz Do you just put a few random blobs in the corners and middle, and then press?? | I started near one corner and snaked it to the bottom. Did this on the left side, and right side (i.e 2 snakes). I used about 3/4 of the tube.
I've been drinking and finding it difficult to get the words but hope that makes sense
