30-06-2009, 5:46 PM
#1 (permalink)
| | Member
Thanks: Gave 0, Got 4 | Wallmounted plasma bigger than fireplace?
Evening all!
I was wondering if anyone has any photos of a wallmounted plasma that is bigger than their fireplace?
I'm thinking of putting an electric fireplace below our newly mounted 60" plasma, the problem is most "modern" fireplaces, which will fit in our room, will be smaller than the plasma.... I can't really imagine what this will look like as 99% of the photos i've seen the fireplace is bigger than the plasma...
Anyone got any photos they could share or done this themselves??
Thanks!!!
p.s not sure if this should go here or plasma or somewhere else....
Reason: .
30-06-2009, 11:32 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 342, Got 178 | Re: Wallmounted plasma bigger than fireplace?
Not sure if this qualifies...
__________________ Kit List: SkyHD, PS3 160GB, Yamaha RX-V1900, Monitor Audio RS6, RSLCR, RSFX, XLS 300PR, Sony 40KDLW2000 LCD. PSN: danmc_82 |
01-07-2009, 5:10 AM
#3 (permalink)
| | Member
Thanks: Gave 0, Got 4 | Re: Wallmounted plasma bigger than fireplace?
Nah overall the fireplace [surround] is bigger than the tele.....
01-07-2009, 5:52 AM
#4 (permalink)
| | Veteran Member
Thanks: Gave 617, Got 902 | Re: Wallmounted plasma bigger than fireplace?
Maybe you should extend the surrond left and right with a false wall. I'd suggest just shelving left and right but I don't think that would look right.
Lots of stuff. Some silver, some black.
01-07-2009, 7:19 AM
#5 (permalink)
| | Member
Thanks: Gave 202, Got 176 | Re: Wallmounted plasma bigger than fireplace?
You could take a photo of your fireplace, get a photo of a plasma TV and have a play.
Gamertag/PSN: Stormpool
Playing Tekken 6
01-07-2009, 8:25 AM
#6 (permalink)
| | Member
The TV is already up but the fireplace isnt...
I'll take a photo of the tv and photochop a fireplace on I guess but I just dont think it will look right...
The TV is 146cm wide and the widest modern fireplace I can find is 120cm.... not a massive difference!
01-07-2009, 12:15 PM
#7 (permalink)
| | Senior Member
Thanks: Gave 342, Got 178 | Re: Wallmounted plasma bigger than fireplace? Quote:
The TV is 146cm wide and the widest modern fireplace I can find is 120cm.... not a massive difference! | Cant you build one up like mine?
01-07-2009, 12:30 PM
#8 (permalink)
| | Member
Thanks: Gave 0, Got 4 | Re: Wallmounted plasma bigger than fireplace? Quote:
Originally Posted by danmc_82 Cant you build one up like mine? |
Got a pic of yours? Its quite a small wall/roomI have it in though....
Pic attached.
Won't let me attach the pic as it's already attached in; The Official LG PS8000 Plasma Thread
Link to the attachment: |
01-07-2009, 12:32 PM
#9 (permalink)
| | Senior Member
Originally Posted by moony1234 Got a pic of yours? Its quite a small wall/roomI have it in though.... | Look at my first post
01-07-2009, 12:41 PM
#10 (permalink)
| | Member
Thanks: Gave 141, Got 346 | Re: Wallmounted plasma bigger than fireplace? |
01-07-2009, 1:24 PM
#11 (permalink)
| | Member
Ahhh doesnt look bad at all!!
Thanks Jenn :]
01-07-2009, 2:47 PM
#12 (permalink)
| | Member
Thanks: Gave 4, Got 13 | Re: Wallmounted plasma bigger than fireplace?
Here's a pic of my setup I put together back in 2005 |
01-07-2009, 2:53 PM
#13 (permalink)
| | Senior Member
Thanks: Gave 286, Got 97 | Re: Wallmounted plasma bigger than fireplace?
do you not get issues from heat since they are so close and well... heat rises...?
__________________ Home Cinema: PANASONIC 50PZ70B - PS3 - Sony DVP-NS930V - Pioneer VSX 2016 - KEF Cresta 30, KEF Cresta 2, KEF Cresta C, Mission M5AS HiFi: B&W 686 on Super Dreadnoughts - Pioneer PD-D6-J - Rega Mira PM me for PMB V2.0.02 |
01-07-2009, 3:06 PM
#14 (permalink)
| | Senior Member
On mine theres a 5" x 2" piece of timber which stops the heat going under the tv.
02-07-2009, 4:14 PM
#15 (permalink)
| | Member
Mine's an electric fan heater so the heat's directed into the room.
