Lag issues
Old 04-01-2010, 7:21 PM   #1
MI55ION's Avatar
15,074, Level: 29
Points: 15,074, Level: 29 Points: 15,074, Level: 29 Points: 15,074, Level: 29
Activity: 8.3%
Activity: 8.3% Activity: 8.3% Activity: 8.3%
Thanks: Gave 400, Got 355
Lag issues
I noticed yesterday when they had that 4-a-side match going I had just 1 minor issue with lag in a game out of many.
Now that 5-a-side is back on, it's gone back to the usual lag fest.
Does anyone know why that is and why MS/Epic doesn't sort this out permanently?
Old 05-01-2010, 1:11 AM   #2
3,405, Level: 13
Points: 3,405, Level: 13 Points: 3,405, Level: 13 Points: 3,405, Level: 13
Thanks: Gave 36, Got 73
We've been asking the same thing since November 2006 without any proper answers from Epic.
Some bloke from Epic did promise that the lag and host advantage would be far less in Gears 2 but it turned out he was lying just so that everyone would buy the game.
Good luck in getting your answer.
Old 06-01-2010, 4:45 PM   #3
MI55ION's Avatar
15,074, Level: 29
Activity: 8.3%
Thanks. It seems I'm not the only one then. I can't believe that Epic would treat its customers like this and what about MS? Surely they should be applying pressure on Epic to get their act together for such a flagship title. If it wasn't for these lag issues, this game would be perfect.
Old 07-01-2010, 12:27 AM   #4
4,521, Level: 15
Points: 4,521, Level: 15 Points: 4,521, Level: 15 Points: 4,521, Level: 15
Activity: 7.5%
Activity: 7.5% Activity: 7.5% Activity: 7.5%
Thanks: Gave 59, Got 93
And you'll be still asking in 2012.
Old 07-01-2010, 8:23 PM   #5
toon83's Avatar
Thanks: Gave 122, Got 107
lag depends on your connection iv been in party when ppl suffer lag and i dont
host wise they need to remove that or have a host on each side
id love to see the 2 piece removed
Old 07-01-2010, 9:16 PM   #6
3,405, Level: 13
Lag depends on your connection to the host, not just your connection as a whole. A team of Europeans against a team from America means that one team will lag more than the other because of latency.
A host on each side will only guarantee that two people will not lag.
Bring back the melee stun and remove the auto lock after melee and the two-piece will drastically reduce.
But Epic knows all of this better than us and yet nowt gets done.
