Well its happened again.........
Old 12-09-2009, 10:02 PM   #1
Thanks: Gave 90, Got 62
Turned on Gears tonight for the first time since ranking up to 30 last weekend. Went to carry on with my insane campaign and dropped me to the beginning on Hardcore.........thought it was weird so turned it off and tried again. Exactly the same. Joined a live game and I was rank 1!!!
Seriously angry!!
Has it happened to anyone else and what are the odds on getting it rectified?
Old 12-09-2009, 10:30 PM   #2
2,984, Level: 12
Points: 2,984, Level: 12 Points: 2,984, Level: 12 Points: 2,984, Level: 12
Thanks: Gave 94, Got 40
Re: Well its happened again.........
There's already a thread on something similar:
A word of warning if you clear your cache...
Looks like it happens when you clear your cache.
Old 13-09-2009, 12:22 AM   #3
Cache wasnt cleared, havnt done that for over 6months. I exited to the gears main screen then to dashboard, closed down correctly as Epic 'suggest' and it still knackered it. I really cant be boyhered with it anymore. Hopefully the Gears 3 ranking wont suck b@lls and it'l actually work!
Old 13-09-2009, 8:23 PM   #4
4,531, Level: 15
Points: 4,531, Level: 15 Points: 4,531, Level: 15 Points: 4,531, Level: 15
Thanks: Gave 283, Got 160
yeah this game is to flawed to be enjoyable now, ive defected to COD and no complaints there
Old 13-09-2009, 9:49 PM   #5
It was never really enjoyable anyway, but the ridiculous XP system and the profile deletion really doesnt make me want to go back to it. In fact I wont other than the get the insane achievement. I too have to back to COD 4, other than the Americans hosting at least its fun.
Old 13-09-2009, 10:50 PM   #6
toon83's Avatar
Thanks: Gave 122, Got 107
for rank u should be able to reach rank 30 in a couple of weeks it has loads of flaws but i still enjoy it
Old 15-09-2009, 7:22 AM   #7
10,589, Level: 24
Points: 10,589, Level: 24 Points: 10,589, Level: 24 Points: 10,589, Level: 24
Thanks: Gave 196, Got 244
[QUOTE=MChatterley;10365939]It was never really enjoyable anyway
Why play it then ???
Easy to solve the rank & enjoyment problem.... Don't play ranked just player matches with your mates.
Mark..
P.S. High Geoff catch you on the fishy game soon
Old 15-09-2009, 11:36 AM   #8
[QUOTE=markwww673;10374914]
Mark..
Because Im a bit of a cheevo whore Wanted to get the Horde cheevos which unfortunately meant you needed to be rank 10, 20 , 30, 40 & 50. Cant be bothered now though. It will just sit on the shelf until its forgiven.......Or Epic fix it.
