now where has my journal gone??
Old 28-07-2009, 2:05 PM   #1
3,020, Level: 12
Points: 3,020, Level: 12 Points: 3,020, Level: 12 Points: 3,020, Level: 12
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 154, Got 25
Ive not been in the journal for a few months and thought id take a look as i know im not far of the party like its 1999
it used to tell me where i was up to but its not in there
Old 28-07-2009, 2:12 PM   #2
12,909, Level: 27
Points: 12,909, Level: 27 Points: 12,909, Level: 27 Points: 12,909, Level: 27
Thanks: Gave 548, Got 507
Re: now where has my journal gone??
Have you cleared your cache in the last few months?...
Originally Posted by Paul_T View Post
Just a heads up - thankfully I'm not telling you this because it's happened to me.
I'm reading on another forum that the update to Gears 2 that gives the online ranks, stores your rank within the update - meaning it's stored in the cache.
So guess what will happen if you clear your cache? Yup - you clear your rank.
The cache also stores your progress bars towards achievements in the journal apparently.
Consider yourself warned...
Old 28-07-2009, 2:43 PM   #3
3,020, Level: 12
Activity: 3.8%
no mate not cleared cache at all
Old 28-07-2009, 7:28 PM   #4
15,960, Level: 30
Points: 15,960, Level: 30 Points: 15,960, Level: 30 Points: 15,960, Level: 30
Thanks: Gave 442, Got 809
I just got GOW2 again.
All my stats/progress from when I last owned are all still there in my journal and I cleared my cache a couple of months ago.
Old 28-07-2009, 8:07 PM   #5
2,813, Level: 12
Points: 2,813, Level: 12 Points: 2,813, Level: 12 Points: 2,813, Level: 12
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 72, Got 22
Mines comes and goes
Old 28-07-2009, 8:53 PM   #6
3,020, Level: 12
Activity: 3.8%
thing is lets use party like its 1999 used to be in there it would say how many ive done.
its still popping up in the bottom corner what ive done so not big deal,,but its nice to check on things so you can do that chevo
Old 29-07-2009, 7:25 AM   #7
8,371, Level: 21
Points: 8,371, Level: 21 Points: 8,371, Level: 21 Points: 8,371, Level: 21
Thanks: Gave 253, Got 285
Mine used to occasionally glitch journal when I started the game, try going into a multiplayer lobby then returning to the main screen and going in to check, that used to sort it for me. Restarting the game usually worked too.
