horde help
Old 07-07-2009, 11:47 PM   #1
toon83's Avatar
Thanks: Gave 122, Got 107
horde help
need ppl for help with horde chevos cheers
normal @ wave 46
snow @ wave 26 or 27
Old 08-07-2009, 11:06 AM   #2
2,074, Level: 10
Points: 2,074, Level: 10 Points: 2,074, Level: 10 Points: 2,074, Level: 10
Thanks: Gave 68, Got 22
Re: horde help
I am up for it as I am going for the wave 50 horde achievement.
I am at wave 35 though, hope you do not mind starting from wave 35
toon83 (10-07-2009)
Old 08-07-2009, 3:21 PM   #3
toon83's Avatar
Re: horde help
sure thats fine after a full squad
fr in comin.do u have map packs?
Old 08-07-2009, 4:44 PM   #4
2,074, Level: 10
Re: horde help
Accepted your FR
Sorry, no map packs
Just PM me when you planning to do it, I am free from 8pm - 12pm on weekdays , and free this weekend.
Old 08-07-2009, 7:02 PM   #5
3,020, Level: 12
Points: 3,020, Level: 12 Points: 3,020, Level: 12 Points: 3,020, Level: 12
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 154, Got 25
Re: horde help
me and my mate did them to 47 but had to draft a 3rd person into do to 50,on casual though ,,it was bloody hard we was on it for a few weeks!!,,them horse guys are a nightmare!
are you doing it on normal setting?
i might be up for it but im very rusty now at it
Old 08-07-2009, 7:46 PM   #6
toon83's Avatar
Re: horde help
Originally Posted by hybridkit View Post
Accepted your FR
Sorry, no map packs
will do just a full crew as it will be 2 hard just two of us
hybridkit (10-07-2009)
Old 08-07-2009, 7:54 PM   #7
toon83's Avatar
Re: horde help
will be on casual if u wanna join let me know,prob start @ 35
Old 10-07-2009, 2:01 PM   #8
toon83's Avatar
Re: horde help
normal done now after snow map packs chevo
Old 10-07-2009, 2:03 PM   #9
Conspicuous Member
21,883, Level: 35
Points: 21,883, Level: 35 Points: 21,883, Level: 35 Points: 21,883, Level: 35
Activity: 13.9%
Activity: 13.9% Activity: 13.9% Activity: 13.9%
Thanks: Gave 190, Got 733
Re: horde help
I'm needing to do horde on the Flashback maps - how can I search for a game that's using those maps only?
Old 10-07-2009, 2:36 PM   #10
toon83's Avatar
Re: horde help
you have to set up a private match,pick horde.casual ,start from ur best wave,invite ur friends,pick ur map
if wantin horde the horde do dayone its normal but is easy
what wave u on?
Old 10-07-2009, 2:55 PM   #11
Location: Real guitars don't have strings, they have 5 coloured buttons.
28,493, Level: 41
Points: 28,493, Level: 41 Points: 28,493, Level: 41 Points: 28,493, Level: 41
Activity: 12.9%
Activity: 12.9% Activity: 12.9% Activity: 12.9%
Thanks: Gave 616, Got 940
Re: horde help
I'd be willing to help anybody out. I need Combustible, standard to lvl 50, and snowblind come July 28th.
Old 10-07-2009, 3:28 PM   #12
2,074, Level: 10
Re: horde help
We managed it
I might consider the 'All Fronts' package, so will probably need the achivements later. Will let you guys know then
Old 10-07-2009, 5:13 PM   #13
toon83's Avatar
Re: horde help
nice send us a fr and come 28th we shall play for all horde
-dark corners horde
-normal horde
-snowblind horde
mattclarkie (12-07-2009)
Old 10-07-2009, 5:15 PM   #14
toon83's Avatar
Re: horde help
We managed it
its very cheap cost me 1600 just for the maps but worth every penny
Old 15-07-2009, 6:55 PM   #15
7,766, Level: 21
Points: 7,766, Level: 21 Points: 7,766, Level: 21 Points: 7,766, Level: 21
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 506, Got 349
Re: horde help
im 39 i think carnt remember how to check lol im rusty tho aint played it for ever just bought it again the other day , add me all if you like
Old 15-07-2009, 7:02 PM   #16
9,822, Level: 23
Points: 9,822, Level: 23 Points: 9,822, Level: 23 Points: 9,822, Level: 23
Activity: 9.1%
Activity: 9.1% Activity: 9.1% Activity: 9.1%
Thanks: Gave 150, Got 181
Re: horde help
toon83. I need to do 1-10 on under hill on snowblind.
do you fancy helping me out if you've got the map pack?
Old 15-07-2009, 8:16 PM   #17
toon83's Avatar
Re: horde help
i have them all and yes i will help
Old 16-07-2009, 12:46 PM   #18
9,822, Level: 23
Activity: 9.1%
Re: horde help
didn't catch you online later last night.
managed to get the achevo with some randoms in the end.
thanks anyway.
