Need to pick up a power supply for a linksys Pap2
Old 15-01-2009, 10:09 PM   #1
Romero's Avatar
4,113, Level: 15
Points: 4,113, Level: 15 Points: 4,113, Level: 15 Points: 4,113, Level: 15
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 55, Got 35
Bought one of these units off ebay, and the powersupply has failed (checked it against a working one) just wondering if there are any reasonable priced suppliers in the UK where I can pick one up, its rated at 5V 2A, I checked maplins they don't have anything that I can see that would be suitable.
Thanks in advance
Old 17-01-2009, 1:12 PM   #2
Romero's Avatar
4,113, Level: 15
Activity: 1.7%
Re: Need to pick up a power supply for a linksys Pap2
anyone got an idea of where to pick one up?????
Old 17-01-2009, 4:35 PM   #3
Chris Muriel's Avatar
15,699, Level: 30
Points: 15,699, Level: 30 Points: 15,699, Level: 30 Points: 15,699, Level: 30
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 510, Got 629
Maplins have this one :
AC/DC Fixed-Voltage Switched Mode Power Supplies > Maplin
Their code L45BL will deliver up to 4 amps.
Some here will do it also :
Power Supply 5V DC, 2A
Chris Muriel, Manchester
Old 17-01-2009, 8:28 PM   #4
Romero's Avatar
4,113, Level: 15
Activity: 1.7%
Thanks Chris, wouldn't the 4amps be to much for the Pap2? it says something like 2Amp Max on the old psu?
Old 17-01-2009, 10:02 PM   #5
15,699, Level: 30
Activity: 11.1%
The 2A max refers to the maximum capacity of the power supply; it was designed to deliver no more than 2 amps (but would have been fine delivering 1 amp or 500 mA also.
A 4 amp supply can deliver enough current to support any equipment that draws up to 4 amps - including your possible need for 2 amps.
The specifications for your PAP2 should tell you what it's maximum current draw should be - probably actually less than 2 amps.
Old 18-01-2009, 3:52 PM   #6
Romero's Avatar
4,113, Level: 15
Activity: 1.7%
Ah ok so if the psu is rated at 5amps and the pap2 only requires 2amps it will only draw down the 5volts at 2amps. Thanks for lesson in power Chris
