Help with VOIP --> BT LINE
Old 08-01-2009, 12:56 PM   #1
1,960, Level: 10
Points: 1,960, Level: 10 Points: 1,960, Level: 10 Points: 1,960, Level: 10
I am looking at installing a VOIP system (I think) to a house.
Basically a rebuilt house with CAT5 installed to every room for computer network, and office.
There is no telephone sockets in the room, and I would like to distribute telephone calls via the CAT5. All the ports run back to a wall cabinet and terminate in a patch panel.
I would like to be able to connect to 3 telephone lines (Fax / work / personal) and distribute them to the phones in the house via a PoE switch.
I am not looking for internet based calling.
However the bit I am missing is the device to distribute the calls and connect to the BT lines and to control the IP Phones.
Any one have any suggestions on a system that I can install to do this - I am not after a fall blown telephone system, some people have recommend Astrix on a server, but I was after a "black box" solution.
Many thanks
Old 12-01-2009, 10:57 PM   #2
1,958, Level: 10
Points: 1,958, Level: 10 Points: 1,958, Level: 10 Points: 1,958, Level: 10
Re: Help with VOIP --> BT LINE
Avaya Quick edition is quite a cool set up, but i think they are thinking of ending its manufacture so you might get them cheap.
All of the phones hold the configuration so there is no need for a central box and if one fails the others keep running
It is mainly VOIP but you can get analogue modules to plug in to it.
Siemens BizIP is a funky little box but i dont think that has analogue just ISDN and SIP
Old 20-01-2009, 10:51 PM   #3
TOMMOHAWK_UK's Avatar
4,203, Level: 15
Points: 4,203, Level: 15 Points: 4,203, Level: 15 Points: 4,203, Level: 15
Thanks: Gave 53, Got 160
If you have a spare PC then I would highly recommend you look at trixboxCE. Fonality trixbox CE, an Asterisk-based PBX Phone System (formerly Asterisk@Home) | trixbox and look for the community edition. I have installed it at work and we are in the process of migrating to it.
