Combination Skype and Landline Phones
Old 01-12-2008, 11:09 AM   #1
2,418, Level: 11
Points: 2,418, Level: 11 Points: 2,418, Level: 11 Points: 2,418, Level: 11
Thanks: Gave 19, Got 8
Hi All,
First post in this section......
I currently have a 3 handset DECT phone set (a BT model) and also use a Linksys CIT200 for Skype (I travel a bit with work).
Anyway, the BT DECT system has broken and I am in the market for a replacement.
It occurred to me that I should be able to combine both the landline and Skype functionality in a single phone. I have looked around at what is available but most of the combination systems require you to connect the system directly to a PC or a Router. I have a PC on 24/7 upstairs which is where my cable broadband comes into the house. This PC is used primarily for media streaming but also is running Skype. The CIT200 has a USB dongle that connects to the PC but allows the CIT200 handset to operate like any other DECT phone anywhere around the house.
So, I cannot find an all in one solution that will allow me to connect a base unit directly into my wall phone socket downstairs (I only have one of these in the house - hence 3 handset DECT system) and also connect to Skype running on a PC upstairs 'wirelessly'.
Does anyone out there know of such a system?
Andrew
Old 02-12-2008, 9:37 AM   #2
Cable Monkey's Avatar
18,572, Level: 33
Points: 18,572, Level: 33 Points: 18,572, Level: 33 Points: 18,572, Level: 33
Thanks: Gave 13, Got 252
Award-Showcase
Re: Combination Skype and Landline Phones
Siemens Gigaset C475 IP DECT VoIP Telephone? Don't know personally but it seems to fit the bill having both DECT and VoIP in its title.
aspendl828 (04-12-2008)
Old 04-12-2008, 3:44 PM   #3
2,418, Level: 11
Thanks for the suggestion - I've had a look at the Seimens phones and although it appears to do everything I was looking for the £200+ price tag put me off a bit!
I've ordered a 3 handset Panasonic DECT for under £80 and I'll stick with the CIT200 for Skype.......
Old 07-12-2008, 11:50 PM   #4
2,795, Level: 12
Points: 2,795, Level: 12 Points: 2,795, Level: 12 Points: 2,795, Level: 12
I have phillips 321 has proven reliable but requires a pc turned on to use skype
Old 12-02-2009, 11:33 AM   #5
2,484, Level: 11
Points: 2,484, Level: 11 Points: 2,484, Level: 11 Points: 2,484, Level: 11
I'm also looking for a combination VoIP and Landline set-up. There doesn't seem to be anything available which meets all the following requirements ...
- Skype-compatible
- Must still work when PC is off
- Includes answering machine for landline
- Must support the addition of 1 or 2 additional handsets
The Netgear SPH200D comes pretty close, but doesn't seem to include an answering machine. It also seems to get occasional reports of unreliability.
Any other suggestions, or do I just need to wait a few months for the market to develop? Thanks.
