Mini Fridges
Old 15-09-2009, 4:22 AM   #1
943, Level: 6
Points: 943, Level: 6 Points: 943, Level: 6 Points: 943, Level: 6
Mini Fridges
Hello,
I am looking for a mini-fridge as a few months ago, mine broke down. I unfortunately couldn't go buy another one from where I got that one because the store I got it from (Woolworths) went out of business.
I have looked around online for mini-fridges but none of the ones I found fulfil all my requirements (or they had really bad user reviews).
Does anyone know of any good mini fridges or coolers?
Here are some requirements:
-It will be in my bedroom so it can't be too noisy but I can live with some constant fan noise if it's not too loud.
-Big enough to hold a minimum of 9 standard drinks cans so that I can put in a 6-pack of Cola and some food.
-Available in the UK.
If anyone knows of any, I appreciate any information.
Thanks.
P.S.: Not entirely relevant but I've found a few mini-fridges listed at "6 Litres" yet according to the user reviews only hold 6 cans. Last time I checked, 1 litre = 1,000ml and 1 can = ~350ml
Old 15-09-2009, 10:03 AM   #2
5,309, Level: 17
Points: 5,309, Level: 17 Points: 5,309, Level: 17 Points: 5,309, Level: 17
Thanks: Gave 4, Got 4
Re: Mini Fridges
I am also on the look out for a mini fridge and came across this. Not sure if this one is any good? It seems okay to me.
Homeson Hotel Mini bar Fridge SILENT, NEW LOW PRICE!!! on eBay (end time 17-Sep-09 13:34:42 BST)
Seems cheaper on the link to their real website too:
DirectStore UK
Old 15-09-2009, 12:40 PM   #3
Uridium's Avatar
33,227, Level: 44
Points: 33,227, Level: 44 Points: 33,227, Level: 44 Points: 33,227, Level: 44
Activity: 23.5%
Activity: 23.5% Activity: 23.5% Activity: 23.5%
Thanks: Gave 527, Got 1,810
Re: Mini Fridges
We got one of these a few mnths ago to take camping.
Nice and quiet and will hold six or so cans and a little more.
Buy 6 Litre Mini Fridge. at Argos.co.uk - Your Online Shop for .
Agros have a decent range of mini fridges if this isn't what you want though
Old 15-09-2009, 1:45 PM   #4
943, Level: 6
Re: Mini Fridges
Thanks but that one doesn't hold enough.
DirectStore UK
I will have to measure the space I have but I think that's too big to fit in my room.
