linksys pap2 help
Old 02-09-2009, 8:58 PM   #1
1,490, Level: 8
Points: 1,490, Level: 8 Points: 1,490, Level: 8 Points: 1,490, Level: 8
linksys pap2 help
I have a pap2 connected to my router which works fine while using it with 1 line only but when we try to use both phones together the lines both break up? But we can use 1 pap2 phone and one skype dual phone at the same time and it works great what is the issue with the pap2??
Old 03-09-2009, 3:54 PM   #2
Caprica's Avatar
Thanks: Gave 66, Got 25
Re: linksys pap2 help
Firstly.. Port forward within your router
Secondly.. If your in the UK dont use a USA codec as changes have to be made on the fly.(Im in the UK and use G711a)
Also.. what BB speed are you on, as a poor upload speed will cause breakup.
Old 04-09-2009, 9:49 AM   #3
1,490, Level: 8
Hey caprica
Port forwarding? BB speed? im a total novice i don't know what these things are!
thanks.
Old 04-09-2009, 3:23 PM   #4
Chris Muriel's Avatar
15,699, Level: 30
Points: 15,699, Level: 30 Points: 15,699, Level: 30 Points: 15,699, Level: 30
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 510, Got 629
Port forwarding for Skype needs to be set up on your router via its admin pages :
Port Forwarding Skype on the FRITZ Annex-A v06.03.91
To test your broadband speed Google "Broadband speedtest" or similar and go to a suitable website that will let you run the speedtest. Make a note of the Upload or upstream speed result.
Chris Muriel, Manchester
Old 07-09-2009, 9:29 PM   #5
1,461, Level: 8
Points: 1,461, Level: 8 Points: 1,461, Level: 8 Points: 1,461, Level: 8
My husband's friends' highly recommended supportrix.com for issues like these. They are excellent.
