VoIP question about Fring & Sipgate
Old 03-08-2009, 10:44 PM   #1
2,570, Level: 11
Points: 2,570, Level: 11 Points: 2,570, Level: 11 Points: 2,570, Level: 11
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 1, Got 6
Does anyone know if the Fring download for the Nokia 5800 will enable my mobile to make calls via my Sipgate account?
Old 21-08-2009, 10:02 PM   #2
1,980, Level: 10
Points: 1,980, Level: 10 Points: 1,980, Level: 10 Points: 1,980, Level: 10
Thanks: Gave 0, Got 2
Re: VoIP question about Fring & Sipgate
Fring will let you call any VOIP provider set up on your mobile. I assume you want to use wifi rather than mobile data. You will need the 3g version of the Nokia 5800. You should also download a hotspot finder such as wefi.
I myself only use sipgate for incoming calls using their free number; they are very expensive for outgoing calls. This allows me to have an UK number for friends to make a local call. I use smartvoip for outgoing calls at the moment but periodically switch as prices keep on changing.
Dusty
Old 31-08-2009, 11:41 AM   #3
1,479, Level: 8
Points: 1,479, Level: 8 Points: 1,479, Level: 8 Points: 1,479, Level: 8
I also use smartvoip for outgoing calls, it is the cheapest i have found now. I only use fring on my iphone when have WIFI, however, only for Message.
Old 02-09-2009, 1:42 PM   #4
2,563, Level: 11
Points: 2,563, Level: 11 Points: 2,563, Level: 11 Points: 2,563, Level: 11
Thanks: Gave 1, Got 3
i prefer to use voipdiscount as it includes UK in the freedays list.
