13-10-2009, 5:03 PM
#1 (permalink)
| | Member
Thanks: Gave 4, Got 1 | Wheel stand pro for forza 3
For anyone whos been using the wheel stand pro, does the clamps hold the steering column in place even under force. I was thinking that after using it for sometime that the steering column would lose its strength or start to loosen.
Are there any issues using the wheel stand pro with the xbox360 steering wheel and pedals, and are you able to hold the xbox360 pedals in place?
Any help would be appreciated.
Really want to use steering wheel on Forza 3 from the get go. Used joypad with Forza 2 and when I did get steering wheel, pedals moving was always an issue, and couldnt get near my joypad times. I figure only way I would stick with steering wheel is if I dont touch the joypad on the game at all.
13-10-2009, 8:57 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 104, Got 125 | Re: Wheel stand pro for forza 3
I just got a WSP and have been using it for a week now and i have to say it is excellently engineered. I haven't had one facet of the wheel be it the wheel itself or the pedals move around when playing, doesn't matter how much i rag it about
All you have to do is to make things hand tight because they use very good and very clever fixings.
As for the pedals, once you use the plate and fix them to the stand they are going nowhere, you'll have to push the whole stand through whatever's in front of you to get them to move and even then they'll still be fixed to the stand
__________________ Gamertag: Kinetic Frenzy
PSN Name: Kinetic_Frenzy |
14-10-2009, 10:37 AM
#3 (permalink)
| | Senior Member
Thanks: Gave 391, Got 284 | Re: Wheel stand pro for forza 3
Better get an order in now then so u have it, order now prob may be monday/tuesday u will have it.
Not used mine with the 360 wheel but i agree it's a stunning bit of kit.
__________________ My Setup AMD Phenom II x3 720BE @ 3.5Ghz, XFX ATi HD4870, Corsair 8Gb XMS3, OCZ StealthXStream 500W, Coolermaster Elite 335 - Logitech G25 & wheel stand pro - Acer Ferrari One |
14-10-2009, 11:07 AM
#4 (permalink)
| | Senior Member
Thanks: Gave 27, Got 26 | Re: Wheel stand pro for forza 3
Which wheel is everyone using? I want to get a wheelstand pro and wheel for Forza but i dont want any crap.
My Xbox Live Gamertag is Screemer
My PSN Username is Screemer75 Panasonic 42" V10, Onkyo SR875, Monitor Audio Radius Speakers, Monitor Audio RSW-12 Sub, PS3, 360 Elite, Sky HD, Apple Tv, QED cables |
14-10-2009, 1:48 PM
#5 (permalink)
| | Senior Member
Hi Screemer, The M$ wheel is very good for its price of £70 and i think Game may still be doing it for £60 when bought with anything else (just buy the cheapest thing in the store). I'd held off for ages from getting one thinking that it was poor for some reason but it's easily every bit as good as my memories of the Logitech DFP (PS3 only) which itself is a very good wheel...
However if you want the uber wheel then be prepared to part with uber cash and get yourself the fanatec. Just make sure if you do that your interest in Forza 3 is more than a fad!
14-10-2009, 1:59 PM
#6 (permalink)
| | Member
Thanks: Gave 4, Got 1 | Re: Wheel stand pro for forza 3
I got MS Official Wheel and pedals and think its a quality product, and just ordered the wheel stand pro after alot of reading around these forums.
I am now trying to find out if I can add pedals with clutch and gear stick to my MS wheel at a reasonable price as I can not pay up for fanatec wheel. If I had the cash then the Fanatec would be my first choice.
14-10-2009, 2:09 PM
#7 (permalink)
| | Senior Member
Thanks: Gave 391, Got 284 | Re: Wheel stand pro for forza 3 Quote:
Originally Posted by Ayman I got MS Official Wheel and pedals and think its a quality product, and just ordered the wheel stand pro after alot of reading around these forums.
I am now trying to find out if I can add pedals with clutch and gear stick to my MS wheel at a reasonable price as I can not pay up for fanatec wheel. If I had the cash then the Fanatec would be my first choice. | -Na sorry pretty sure that not possible with the MS wheel.
14-10-2009, 2:23 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 27, Got 26 | Re: Wheel stand pro for forza 3 Quote:
Originally Posted by Kinetic Frenzy Hi Screemer, The M$ wheel is very good for its price of £70 and i think Game may still be doing it for £60 when bought with anything else (just buy the cheapest thing in the store). I'd held off for ages from getting one thinking that it was poor for some reason but it's easily every bit as good as my memories of the Logitech DFP (PS3 only) which itself is a very good wheel...
However if you want the uber wheel then be prepared to part with uber cash and get yourself the fanatec. Just make sure if you do that your interest in Forza 3 is more than a fad!  | Alreet Decker lad, how goes it? WHich Fanatec is it? They seem to have loads on there site? Do i have to order through Fanatec or does anywhere else sell them?
14-10-2009, 2:28 PM
#9 (permalink)
| | Senior Member
I loose track Screemer, there's so many different versions and it depends which consoles you want it to work on.
I think you need the one that works on everything as this i think is the only one which importantly works with the 360.
@ GMC sorry mate i haven't forgotten i promised pictures of my wheel set up on the wheel stand i will do it this week.
14-10-2009, 2:45 PM
#10 (permalink)
| | Member
Thanks: Gave 15, Got 73 | Re: Wheel stand pro for forza 3
I've also just ordered the WSP and I am ready to buy the MS Wheel,i'm hoping this gets released in the UK.
19-10-2009, 6:31 AM
#11 (permalink)
| | New Member
Thanks: Gave 1, Got 0 | Re: Wheel stand pro for forza 3 Quote:
Originally Posted by Kinetic Frenzy I loose track Screemer, there's so many different versions and it depends which consoles you want it to work on.
@ GMC sorry mate i haven't forgotten i promised pictures of my wheel set up on the wheel stand i will do it this week.  | Its the Turbo S version you need, its the multi platform version and therefore only one compatible with the 360. I have one on order myself (the Clubsport edition as this comes with the all aluminum pedals the other version comes with standard pedals). I will be using it with both Forza and GT5 when it is released.
Its the best "mid priced" wheel out there, all in costing me about £550!! But bear in mind that cost includes the Fanatec wheel stand which bumped the price up about £100. I went for the Club sport edition simply because If I bought the standard edition the uber pedals would be another £150 when I bought separately at a later date (which I know I would have!!). So there is a (relative) saving to be made in buying them as an integral package.
19-10-2009, 9:56 AM
#12 (permalink)
| | Senior Member
i'm sure the fanetec will be good but i doubt it will be 10x better than the M$ wheel. Personally i'd have to play racing games non stop to justify such expenditure...
19-10-2009, 5:56 PM
#13 (permalink)
| | New Member
Originally Posted by Kinetic Frenzy i'm sure the fanetec will be good but i doubt it will be 10x better than the M$ wheel. Personally i'd have to play racing games non stop to justify such expenditure... |
Lol!! You could well be right but **** it I know I wont regret it and I pretty much will be playing nothing else for a good few months at least!! then when GT5 is finally released it will definately justify my flagrent disregard of the credit crunch
19-10-2009, 7:30 PM
#14 (permalink)
| | Member
Thanks: Gave 150, Got 61 | Re: Wheel stand pro for forza 3 Quote:
Originally Posted by Kinetic Frenzy i'm sure the fanetec will be good but i doubt it will be 10x better than the M$ wheel. Personally i'd have to play racing games non stop to justify such expenditure... | ...and for that reason, I'm out!
The Wheel Stand Pro looks really good tho, might have to invest in one soon! |
19-10-2009, 7:40 PM
#15 (permalink)
| | Senior Member
Thanks: Gave 40, Got 120 | Re: Wheel stand pro for forza 3
I'm going to have a go at making a Wheel Stand Pro variation, doesn't look much to it really.
BYF's budget rig: CPU Intel E5200 @ 3.5ghz, RAM 4gb DDR800 Corsair , GFX HD4870 1gig, M/B Gigabyte EP43-S3L, HSF Arctic Cooling Freezer Pro, HDD 500Gb Western Digital AAKS + LG DVD-RAM rewriter, PSU Silver Power SP-SS500 (Seasonic), CASE Asus Cheap Charlie. ALL for £440 |
