AVForums - Free Audio Visual electronics advice and information
AVForums.com twitter page AVForums.com facebook page AVForums is a member of CEDIA. THX certified reviewer.  Click for more information. AVForums reviewers are ISF Certified.  Click for more information.
Forum List Register Blogs Information Social Groups Search Today's Posts Mark Forums Read
Go Back   AVForums.com > Forums > Other Home Cinema Components > Flat Screen TV Brackets and Mounts
Latest popular product pricesPowered by
Alphason Designs ACT1100-CH
AV4Home LF750
StarTech.com 4 Port Wall Mount VGA Video Splitter - Video splitter - 4 ports - cascadable
B-Tech BT8432B
AV4Home LF750
StarTech.com 4 Port Wall Mount VGA Vi...
B-Tech BT8432B
S&C Group ZIN421458/BKI-BR
B-Tech BT7514S
AXIS COMMUNICATIONS AXIS - CCTV lens ...
AV4Home LF620
Samsung WMN1000B TV Wall Mounting Kit
B-Tech BT8422
 More...Prices updated July 30th at 1:30pm and include delivery.
LinkBack Thread Tools
Old 19-06-2007, 11:00 AM   #1
Nexus AVF LCD500 Mount
I purchased a Nexus AVF LCD500 with my Philips 32pfl5522d. I had seen some posts that said they had to cut the mount and it was difficult to connect the two halfs on the wall as they initally fit at an angle. My experience of fitting the two parts together was simple with no problems at all. This may just be due to the LCD model I have but I found it great, it now looks so neat and flush to the wall.
I did have one issue worth mentioning. I drilled the wall with a 8mm bit to 65mm deep as the instructions stated. I inserted the supplied Rawplugs and attempted to fix the back plate using the supplied screws. Using a very large Philips screwdirver I could not get the screws in more than half way and I was in danger of snaping the heads off the screws! The only way I could get the screws all the way home was to drill out the center of the Rawplug with a 5mm wood bit, even then the supplied screws where very hard to drive home.
For £40 I am very happy with the result as I wanted it as flush as possible.
pdent02 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookShare on Twitter
avf, lcd500, mount, nexus
Optimised for Firefox
AVForums.com is owned and operated by M2N Limited
Copyright © 2000-2010 M2N E. & O. E.
