Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > Flat Screen TV Brackets and Mounts
Latest popular product pricesPowered by
ALPHASON AG942B Unique flat panel support precision engineered to a high standard, complete with universal fixing bracket for up to 43†Plasma or LCD screens.
Q Acoustics Q-TV2 CANTILEVER BRACKET
MELICONI GHOST 430 WALL BRACKET FOR UP TO 55 INCHES
AXIS COMMUNICATIONS AXIS - CCTV lens - fixed iris - CS-mount - 4 mm - f/2.0
ALPHASON AG942B Unique flat panel sup...
MELICONI GHOST 430 WALL BRACKET FOR U...
AXIS COMMUNICATIONS AXIS - CCTV lens ...
MELICONI GHOST 210 WALL BRACKET FOR 1...
VIVANCO OneClick TVAIMP205 TV/Audio V...
ALPHASON ALP-ARB1100-2-BLACK
Techlink TWM2 - Wall Bracket For LCD ...
Alphason Designs HES50/3
B-Tech BT8432
 More...Prices updated March 19th at 5:30am and include delivery.
Thread Thread Starter Forum Replies Last Post
Optoma HD70 Wall Mount mattyduk Projectors 12 21-12-2009 9:57 AM
Floor standers or wall mount unseen Speakers 1 12-11-2009 12:08 AM
Help Mounting my TV! Spursman Plasma TVs 37 10-11-2009 10:29 PM
Flat screen wall mounting advice rb2009 Home Cinema DIY 4 10-11-2009 7:50 PM
Old 11-11-2009, 10:52 PM   #1 (permalink)
Baird PR42 HELP CONNER MOUNT
My brother's girlfriend has got a Baird PR42. I asked her for the model number and this is it pr42baird
OK, so what she is after doing is to mount the tv in the corner of the wall, the walls are brick. Now she as had a look in currys and the guy in there said the mount will cost her something like £200. WOW, that seems a lot i said, and there is no way on earth she could buy this as she has young children, her idea was to mount the tv out of the way of the kids. Also, the tv mount would have to tilt forward. Her budget is around £100, can this be done?
Thanks for any help with this.
gavouk is offline   Reply With Quote
Old 12-11-2009, 7:49 AM   #2 (permalink)
Assured Advertiser
m-formonline's Avatar
Thanks: Gave 11, Got 218
Re: Baird PR42 HELP CONNER MOUNT
We have a dedicated corner mount here;
M-Form - 32" to 52" Corner Bracket
A little over the budget but this is a very sturdy and safe bracket designed specifically for mounting into a corner as it uses both walls as mounting points. It also has tilt so you can mount high up away from the kids.
Hope this helps.
Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
m-formonline is offline   Reply With Quote
Old 12-11-2009, 8:57 AM   #3 (permalink)
thxs for that and it looks like it would do the job but £100 is her max she was wonting to only spend £80 but iv got her up to £100 but she would just not go any higher then that is there altenative`s
Old 12-11-2009, 9:07 AM   #4 (permalink)
Assured Advertiser
Fair enough. You should be able to find an alternative type of bracket, maybe a cantilever type, for this sized TV within your budget. We don't have one but check the other assured advertisers on here as they may do.
Regards
Graham
baird, conner, mount, pr42
Copyright © 2000-2010 M2N E. & O. E.
