| Re: tilt and turn 40w4000 wall mount
At the higher-cost end of the scale are the Vogels scissor-arm brackets.
I have a Samsung LE40N73 mounted on a Vogels EFW 6345 bracket. The important thing about this type of bracket is that they allow the TV to pull straight out from the wall, which then provides the clearance to turn a large TV from side to sdie through a large angle. The bracket also allows the TV to tilt.
It's expensive (over £200 3 years ago) but it's a very nice piece of kit and operates very smoothly.
The Samsung is a 200x200mm VESA mount which is at the bottom of the Vogels bracket size range. You would need to check that the bracket would fit to your TV of course.
There are much cheaper options if you don't need this range of movement.
