7134 based TV Tuner £29.99 at Aldi
Old 04-07-2003, 2:58 PM   #1
gingercat's Avatar
4,817, Level: 16
Points: 4,817, Level: 16 Points: 4,817, Level: 16 Points: 4,817, Level: 16
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 13, Got 27
Medion PV Tv Tuner Card £29.99
http://www.aldi-stores.co.uk/special...offers_nav.htm
"Upgrade your computer with this card and access TV, FM radio and teletext to your monitor. The software also enables the digital recording of television programmes onto your hard drive. The unit contains the state-of-the art Philips 7134 chip set giving ultimate reliability."
Think it's a 1 week only offer starting next thursday (10/07/2003)
Old 04-07-2003, 5:23 PM   #2
Loafer316's Avatar
4,080, Level: 15
Points: 4,080, Level: 15 Points: 4,080, Level: 15 Points: 4,080, Level: 15
Hmm from the looks of it could be similar to the Lifeview 3000
Old 04-07-2003, 6:45 PM   #3
njiri's Avatar
6,852, Level: 19
Points: 6,852, Level: 19 Points: 6,852, Level: 19 Points: 6,852, Level: 19
Is that good or bad?
Old 04-07-2003, 10:24 PM   #4
Loafer316's Avatar
4,080, Level: 15
If you check out the sticky in the HTPC forum it'll explain a bit more...PB-TV100 from pcworld is a card based on the phillips 7130 chip and is pretty good ..(i have that one) and i believe the 7134 chip has the extra nicam and and the fm tuner. should be a good card.....but wont really know until someone gets one.
Old 05-07-2003, 7:08 AM   #5
Blighty_Boy
Posts: n/a
does this card accept direct video in ie composite or is it UHF only ???
Old 05-07-2003, 8:24 AM   #6
gingercat's Avatar
4,817, Level: 16
Activity: 1.4%
It has SVideo and Composite in too, shall we form an orderly queue ready for Thursday then?
Old 06-07-2003, 8:13 AM   #7
6,445, Level: 19
Points: 6,445, Level: 19 Points: 6,445, Level: 19 Points: 6,445, Level: 19
Tv Tuner Card
Can the Medion PV Tv Tuner Card be fitted to all computers (including laptops)? and is it easy connect up, or is it advisable to get someone with technical competance to do it?
Old 06-07-2003, 8:47 AM   #8
nathan_silly
Posts: n/a
Re: Tv Tuner Card
err how on earth can you fit a PCI card into a laptop????
It'll fit into PC's with a spare PCI slot.. switch the PC off. Remove the case.. remove the blanking plate. Slot the card in. Screw in the screw over the blanking plate.. put case back on, switch PC on.. install drivers.
HTML code is On
