I’ve been looking at this model and I’ve done a Google Product search and everyone else is changing more so looks like shopping around gives the consumer a better deal at the end of the day.
All I need to do is, sort out my debit BT issues tidy that up and save up for LCD video projector. So can you get the full width of the image displayed with this model as if you, where watching it on the pc because I know some LCD plasma flat screens crop off the sides of the image same with CRT and my Toshiba CRT as at least 15% of the image on the horizontal cropped off or sorry I mean (over scanned).
What is the price of the bulbs because that is really the running cost of owning a video projector isn’t it.
Are there many different manufactures makes that will fit the Samsung LCD video projector is it though Samsung only, I guess the bulbs can’t be as expensive as xenon bulbs for cinema projectors those I just couldn’t believe the price when I worked in the cinema years ago, handle with care extreme care LOL.
Also what is the maximum size the image can it be blow up to for 15 feet room length width is 11 feet and I only need 8 or 9 feet at best does it, have any variable size control besides zoom and focus also how loud is the fan on the projector measured in dba at different distances from close near by to seated position.
What about an anamorphic lens, can one be fitted adapted to it.
