Ex-Demo Sunfire Processor/Power Amplifier/Subwoofer Bargains
Old 09-05-2008, 12:23 PM   #1
Assured Advertiser
Richard Torble's Avatar
6,759, Level: 19
Points: 6,759, Level: 19 Points: 6,759, Level: 19 Points: 6,759, Level: 19
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 93, Got 231
Sunfire True EQ Subwoofer
• 2700-watt amp featuring patented Tracking -Downconverter power supply
• Frequency response: 18 Hz to 100 Hz (+0, -3 dB)
• Greater than 110 dB peak SPL with room gain
• Measurement microphone and self-adjusting contour circuitry
• Input coupling is optical and accepts balanced, standard and high-level inputs
• Bore 8 inches - stroke 2.35 inches (over 235 cubic inches total air volume displacement)
• Crossover points variable from 30 Hz to 100 Hz
• Input level (volume) control
• Phase continuously adjustable 0° to 180°
• Passive 70 Hz 6 dB per octave hi-pass line level -output for satellite loudspeakers
• Dimensions: 11" by 11" by 11"
RRP - £2194 Forum Price - £1152
Sunfire TGP5 Surround Processor
• Two HDMI inputs and one HDMI output
• IP-addressable Ethernet port plus RS-232 compatibility
• 7.1 Channel Dolby Pro Logic IIx, Dolby Digital, Dolby Digital EX, DTS, DTS-ES and DTS Neo:6 decoding, plus Sunfire's exclusive Side-Axis outputs for 9.1 channels total playback!
• Second zone plays sources independent of the main zone
• Full-time digital downmix provides accurate two-channel output for tape recording, digital outputs, and second zone from multichannel digital sources
• Direct two-channel analog bypass mode
• Preprogrammed and learning remote control with LCD display
• FM/AM tuner with 40 presets and Dynamic Tuner Noise Reduction.
• Simulated surround mode converts stereo inputs into 5, 7 or 9 channels of output
• DSP tone controls
• Three HDTV compatible wide-bandwidth component video inputs and two outputs
• Format conversion between composite, S-VHS and component
• Six audio/video inputs, each with audio, S-video and composite video
• Three audio-only inputs, including Moving Magnet Phono input for LPs
• Eight analog audio inputs for DVD-A, SACD, or other external multichannel source
• Digital audio (S/PDIF) inputs for six sources: four coax or optical, plus two coax only
• Coaxial and optical digital (S/PDIF) outputs provide two-channel digital downmix from 5.1 sources
• Balanced outputs for primary 7.1 channels
• Four subwoofer outputs
• Comprehensive all-digital bass manager with crossover frequencies of 40 to 160Hz
• 24-bit A-to-D converter and 24-bit/192kHz Multibit D-to-A converters for the ultimate in sound quality
• Separate trigger outputs and infrared inputs for both zones
• High-current (500mA total) trigger outputs.
RRP - £3499 Forum Price - £1836
Sunfire TGA7400 7 Channel Power Amplifier
• 400W x 7 into 8 ohms
• 800W into 4 ohms
• 1600W into 2 ohms (time-limited basis)
• Sunfire’s patented Tracking Downconverter™ technology
• Two output options for the main left and right channels
• Intrinsic frequency response 1 Hz to 80 kHz
• Signal present auto-on switch senses input signal on any channel and automatically powers up
• 12VDC trigger input with 1/8" mini jacks, as well as plug-in screw-terminal strip
• Balanced XLR and unbalanced RCA inputs
• High-quality five-way binding posts
RRP - £3245 Forum Price - £1700
We are also able to offer an additional 5% discount if ALL 3 items are purchased at the same time, which would bring the total to £4,450, representing a saving of £4,488 over the SRP.
As per forum rules, please PM me with any enquiries.
HTML code is On
