Professional Quality HDMI Cable 2.4M v1.3
Old 12-01-2008, 6:12 PM   #1
funkyspider's Avatar
7,994, Level: 21
Points: 7,994, Level: 21 Points: 7,994, Level: 21 Points: 7,994, Level: 21
Thanks: Gave 285, Got 496
Not the cheapest, but decent length and should be decent quality.
Play.com. £9.99, free delivery and 6% Quidco if you have it.
http://www.play.com/Electronics/Elec...tml?P36=75QD7S
Just edited to say I meant build quality. Picture quality with HDMI will be the same regardless of how much you pay assuming the cable isnt faulty - which of course where build quality helps. I hope noone was misled.
avnutter (14-01-2008)
Old 15-01-2008, 1:46 AM   #2
5,853, Level: 18
Points: 5,853, Level: 18 Points: 5,853, Level: 18 Points: 5,853, Level: 18
Activity: 12.1%
Activity: 12.1% Activity: 12.1% Activity: 12.1%
Thanks: Gave 576, Got 148
Re: Professional Quality HDMI Cable 2.4M v1.3
I bought one a while back, and the one I got was perfectly fine and serviceable, but the build quality isn't how it looks on the picture. It looks like a thick woven cable, but in actuality it just seems like a hollow plastic tube, with a weave (or possibly just paint) round it, and probably a very thin cable inside
It does the job, but there's no real advantage over a really cheap one.
HTML code is On
