360 HD DVD Drive + Superman Returns £114.99 @ HMV
Old 07-10-2007, 5:49 PM   #1
dannius's Avatar
7,806, Level: 21
Points: 7,806, Level: 21 Points: 7,806, Level: 21 Points: 7,806, Level: 21
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 131, Got 161
Instore, saw it today. Previous price for a Xbox 360 HD DVD drive at HMV was £129.99.
However they are now doing it for £114.99 and throwing in Superman Returns on HD DVD for free, which they usually sell for £27.
Might be of use to someone.
Old 10-10-2007, 10:31 PM   #2
8,829, Level: 22
Points: 8,829, Level: 22 Points: 8,829, Level: 22 Points: 8,829, Level: 22
Thanks: Gave 59, Got 87
Re: 360 HD DVD Drive + Superman Returns £114.99 @ HMV
Sorrry to be lazy, but can you plug an x-box HD-DVD drive into a HTPC USB drive and expect it to work???
Old 11-10-2007, 8:21 AM   #3
Conspicuous Member
nheather's Avatar
17,668, Level: 32
Points: 17,668, Level: 32 Points: 17,668, Level: 32 Points: 17,668, Level: 32
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 595, Got 1,168
I'm not 100% sure of this (I doubt it) but I've heard that you can take the drive out the the enclosure and install it in a PC.
Cheers,
Nigel
Old 11-10-2007, 2:44 PM   #4
3,111, Level: 13
Points: 3,111, Level: 13 Points: 3,111, Level: 13 Points: 3,111, Level: 13
Thanks: Gave 54, Got 37
I can't find the thread but I'm sure I read on this forum you can get driver software to run the drive on a PC.
Old 13-10-2007, 8:21 PM   #5
1,908, Level: 10
Points: 1,908, Level: 10 Points: 1,908, Level: 10 Points: 1,908, Level: 10
Thanks: Gave 1, Got 7
do a quick search on the forum or google, you will have lots of results. i have one connected and use PowerDVD. 'superp'
Old 16-10-2007, 6:35 PM   #6
nitram100's Avatar
8,087, Level: 21
Points: 8,087, Level: 21 Points: 8,087, Level: 21 Points: 8,087, Level: 21
Thanks: Gave 366, Got 461
Also, starting from 1st october, any purchased hd-dvd players are eligable for 5 free HD-DVDS from www.xbox.com.
Old 17-10-2007, 12:57 PM   #7
5,096, Level: 16
Points: 5,096, Level: 16 Points: 5,096, Level: 16 Points: 5,096, Level: 16
Thanks: Gave 1, Got 2
cheers for this.
Old 19-10-2007, 7:49 PM   #8
Epoman's Avatar
6,851, Level: 19
Points: 6,851, Level: 19 Points: 6,851, Level: 19 Points: 6,851, Level: 19
Thanks: Gave 153, Got 64
Only £99 at PC World Collect in Store - no free dvd though.
HTML code is On
