Bargin Laptop found!
Old 14-09-2007, 9:10 AM   #1
8,709, Level: 22
Points: 8,709, Level: 22 Points: 8,709, Level: 22 Points: 8,709, Level: 22
Thanks: Gave 368, Got 107
GF wanted a lappy so i set out on a hunt to find one with a budget of £600ish.
After looking around i found her a good one on the net but we had £100 DSG vouchers to spend so thought id pop into pcworld. You would not believe the specs for the price (on offer):
Philips X57
15.4 WSXGA
Core 2 T5500 1.67GHz
2GB DDR2 Ram
nVIDIA 128mb (dedicated)
100GB HD
DVD +/- WR
Bluetooth
Wireless a+b+g
10/100/1000 Ethernet
DVI out
SPDIF Out
Card reader
4 USB 2.0
Vista Ultimate
All for £449.99!!!!
Never thought of a Philips laptop before but its of very good build quality, carnt recomend it enough! Will be buying one for myself in the next few days!
Old 14-09-2007, 10:34 AM   #2
6,795, Level: 19
Points: 6,795, Level: 19 Points: 6,795, Level: 19 Points: 6,795, Level: 19
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 58, Got 20
Re: Bargin Laptop found!
click the link the spec differs
http://www.pcworld.co.uk/martprd/product/seo/572724
Old 14-09-2007, 11:17 AM   #3
8,709, Level: 22
yes your right, its 256mb graphics card!
But it was £449. and had free ram upgrade!
HTML code is On
