4-pack AA Ni-Mh 1600Mah rechargeable batteries £2.99
Old 01-12-2002, 8:05 PM   #1
Assured Advertiser
21,242, Level: 35
Points: 21,242, Level: 35 Points: 21,242, Level: 35 Points: 21,242, Level: 35
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 58, Got 205
4 Pack of 1600 Mah Ni-Mh batteries, £2.99 at 7dayshop
Delivery is only 95p now at 7dayshop.
bit of a bargain.
Mark.
suniil (26-03-2007)
Old 06-12-2002, 12:26 AM   #2
TooManyHobbies's Avatar
6,180, Level: 18
Points: 6,180, Level: 18 Points: 6,180, Level: 18 Points: 6,180, Level: 18
Thanks: Gave 6, Got 16
Thanks for that link got some quality photopaper here at a good price also. Nice link one for the bookmarks.!!!!!!!!!!
And the best bit is NO VAT
Old 06-12-2002, 10:19 AM   #3
tomson's Avatar
7,527, Level: 20
Points: 7,527, Level: 20 Points: 7,527, Level: 20 Points: 7,527, Level: 20
Thanks: Gave 88, Got 189
There are also some 2000 Mah Ni-Mh batteries on there too - for under £6.
Ideal for digi cams.
Old 06-12-2002, 1:57 PM   #4
6,180, Level: 18
Saw the other batt's they are good value, but for me it means yet another charger.
They where doing a deal on a charger 4 X 1850mA Ni-MH AA plus a set of 4 x 2000mA Ni-MH AA for free all for £15.49 and no VAT!
Old 06-12-2002, 2:50 PM   #5
Garrett's Avatar
80,318, Level: 69
Points: 80,318, Level: 69 Points: 80,318, Level: 69 Points: 80,318, Level: 69
Activity: 27.3%
Activity: 27.3% Activity: 27.3% Activity: 27.3%
Thanks: Gave 216, Got 725
Cool
How much longer are the 2000 Mah Ni-Mh batteries likely to last over the 1600’s I use some 1300 and 1500 and although they are different makes the 1500 seem to last 25% to 33% longer(this is on a mini disc)?
Old 06-12-2002, 3:28 PM   #6
6,180, Level: 18
The batteries vary dependant on the type equipment they are used in. I have a digital camera it came with 2 X 1600mA Ni-MH the life on these is reasonably good I have since purchased some 1500mA ones thinking that they will make little or no difference but I was wrong they are down by about 30% when I use the screen and about 15% without. It seems the higher the capacity the greater the ability to recover its voltage so they should make a noticeable difference in the minidisc.
Mark
Old 06-12-2002, 4:18 PM   #7
tomson's Avatar
7,527, Level: 20
I've noticed a small difference between 1500 and 1700 batteries when used in my digicam - so thought i'd give the 2000 ones a try. I doubt there's gonna be a huge difference but you never know. For £5.95 its worth a go.
Old 06-12-2002, 10:16 PM   #8
6,180, Level: 18
Just make sure your charger can charge them mine is limited up to 1600 ones.
Old 06-12-2002, 10:42 PM   #9
Garrett's Avatar
80,318, Level: 69
Activity: 27.3%
Cool
Any thing I should look out for to say whether my charger will charge them or not?
Old 06-12-2002, 11:19 PM   #10
6,180, Level: 18
Just check the paperwork for the charger. You may find that if the charger is not up to it it will not fully charge them. Some charger have a timer function they charge for 8 hours and then go onto a tickle charge to maintain the battery level when the 2000aH battery may require 14 hours of charge they all work differently. The best thing is to contact the manufacturer and ask if you can charge a battery of this capacity but play clever and ask if they do a higher capacity battery.
Old 24-03-2007, 7:33 PM   #11
a27 a27 is offline
3,806, Level: 14
Points: 3,806, Level: 14 Points: 3,806, Level: 14 Points: 3,806, Level: 14
Thanks: Gave 44, Got 28
Re: 4-pack AA Ni-Mh 1600Mah rechargeable batteries £2.99
bit of a bargain.
Mark.
Product cannot be found!
Where's the best price for such now?
Old 24-03-2007, 7:50 PM   #12
Illustrious Mumbler
Mr Incredible's Avatar
19,499, Level: 33
Points: 19,499, Level: 33 Points: 19,499, Level: 33 Points: 19,499, Level: 33
Activity: 9.5%
Activity: 9.5% Activity: 9.5% Activity: 9.5%
Thanks: Gave 1,659, Got 3,433
Geez A27, I Think you should be put forward for the longest delay to respond to a thread. Last post was in December 2002!!! Wake up fgs!!
Try this link
£2.99 + £3.95 delivery for 2500 mAh AA size.
Old 24-03-2007, 7:50 PM   #13
6,746, Level: 19
Points: 6,746, Level: 19 Points: 6,746, Level: 19 Points: 6,746, Level: 19
Thanks: Gave 48, Got 49
http://www.7dayshop.com/catalog/prod...ucts_id=101842
7dayshop Rechargeable Ni-Mh Battery - AA Size (2800mAh) - Pack of 4 £4.29 are a great prive if your charger can handle them
Old 24-03-2007, 10:58 PM   #14
a27 a27 is offline
3,806, Level: 14
Try this link
I was gonna start a new thread asking about the best prices for rechargeables but I thought I'd search first.
I'm thinking of getting these
http://www.7dayshop.com/catalog/prod...ucts_id=101211
as I need a charger too.
Any objections?
Old 25-03-2007, 9:25 AM   #15
6,746, Level: 19
Any objections?
Takes a while to charge the batteries tho . I have this one and very happy
http://www.7dayshop.com/catalog/prod...ucts_id=101059
Old 26-03-2007, 7:19 AM   #16
a27 a27 is offline
3,806, Level: 14
How long would the batteries take to charge on mine?
Old 26-03-2007, 7:51 AM   #17
suniil's Avatar
22,696, Level: 36
Points: 22,696, Level: 36 Points: 22,696, Level: 36 Points: 22,696, Level: 36
Thanks: Gave 836, Got 385
lidl is doing all kind of rechargable batteries for £1.99, it's worth looking www.lidl.co.uk, this thursday
HTH
Old 29-03-2007, 9:41 AM   #18
Tyler Durden's Avatar
6,273, Level: 18
Points: 6,273, Level: 18 Points: 6,273, Level: 18 Points: 6,273, Level: 18
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 134, Got 66
Any idea what capacity the Lidl ones are?
Old 28-10-2007, 12:19 PM   #19
a27 a27 is offline
3,806, Level: 14
I'm actually ready to order now.
Any new recommendations?
Old 28-10-2007, 1:59 PM   #20
kendoll's Avatar
21,298, Level: 35
Points: 21,298, Level: 35 Points: 21,298, Level: 35 Points: 21,298, Level: 35
Activity: 9.1%
Activity: 9.1% Activity: 9.1% Activity: 9.1%
Thanks: Gave 159, Got 557
Whoa. Hold on there, take your time now, don't rush into it
7dayshop is always good for batteries give them another look.
HTML code is On
