19" Widescreen TFT Monitor - £105 Delivered!
Old 01-09-2006, 7:13 PM   #1
Conspicuous Member
Crocodile's Avatar
15,114, Level: 29
Points: 15,114, Level: 29 Points: 15,114, Level: 29 Points: 15,114, Level: 29
Activity: 13.6%
Activity: 13.6% Activity: 13.6% Activity: 13.6%
Thanks: Gave 408, Got 1,147
Hanns-G 19" widescreen TFT monitor with VGA & DVI for £105 including delivery from Amazon.
Having bought one from Dabs last week for what then seemed like a bargain £137, I'm not best pleased.
Fill your boots!
Old 01-09-2006, 11:40 PM   #2
7,755, Level: 21
Points: 7,755, Level: 21 Points: 7,755, Level: 21 Points: 7,755, Level: 21
Thanks: Gave 6, Got 21
Re: 19" Widescreen TFT Monitor - £105 Delivered!
Great price - good reviews as well??
Old 02-09-2006, 8:23 AM   #3
derby4life's Avatar
2,933, Level: 12
Points: 2,933, Level: 12 Points: 2,933, Level: 12 Points: 2,933, Level: 12
Thanks: Gave 22, Got 10
WOW....has anyone got one of these and is it any good ...no dead pix or anything dodgy ....seems sssooooo cheap
Old 02-09-2006, 9:41 AM   #4
Conspicuous Member
Crocodile's Avatar
15,114, Level: 29
Activity: 13.6%
No complaints with mine.
Old 02-09-2006, 10:37 AM   #5
Illustrious Mumbler
Mr Incredible's Avatar
19,499, Level: 33
Points: 19,499, Level: 33 Points: 19,499, Level: 33 Points: 19,499, Level: 33
Activity: 9.5%
Activity: 9.5% Activity: 9.5% Activity: 9.5%
Thanks: Gave 1,658, Got 3,433
Not sure a 900 pixel vertical resolution would be ideal for computer apps.
Old 02-09-2006, 10:40 AM   #6
Conspicuous Member
Crocodile's Avatar
15,114, Level: 29
Activity: 13.6%
Why? What is the "ideal" resolution for all computer apps?
Old 02-09-2006, 10:53 AM   #7
Illustrious Mumbler
19,499, Level: 33
Activity: 9.5%
In my experience I cannot work with anything less than 1024 vertical pixels. Perhaps its a personal thing!
Old 02-09-2006, 11:08 AM   #8
Conspicuous Member
Crocodile's Avatar
15,114, Level: 29
Activity: 13.6%
AFAIK, 900 is the max vertical resolution for a 19" WS panel. Certainly at the budget end.
I think as long as the graphics card supports the 1440 x 900 native res of the monitor, it will be fine. I haven't noticed any issues in the 10 days or so I've had mine.
Old 02-09-2006, 11:20 AM   #9
Illustrious Mumbler
19,499, Level: 33
Activity: 9.5%
It appears that the same unit is offered by Overclockers UK (more expensive) but the spec states:
OcUK Value Hanns-G HW191D 19" Widescreen LCD Monitor - Silver (MO-017-OK)
The OcUK Value HW191D has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 700:1 contrast ratio and excellent viewing angle there is no other TFT/LCD that can match the quality, value or performance.
- 1440 x 900 (WXGA) Optimum Resolution
- 16.2 Million Colours
- 700:1 Contrast Ratio
- 5ms Response Time
- 300 cd/m2 Brightness
- One DVI-D Input
- One Analogue Input
- 3 Years Manufacturer On-Site Warranty (Call Manufacturer direct on )
Looks a very fine specc'd unit with a response time of 5ms and contrast 700:1
Old 02-09-2006, 11:26 AM   #10
Conspicuous Member
Crocodile's Avatar
15,114, Level: 29
Activity: 13.6%
Only thing the bear in mind is the inbuilt speakers. If you're expecting them to be so poor as to make their inclusion pointless, you won't be disappointed!
Old 02-09-2006, 11:30 AM   #11
Illustrious Mumbler
19,499, Level: 33
Activity: 9.5%
Out of interest, can the unit be rotated through 90 degrees? I think you an get software that rotates the image for panels of such a persuasion!
Old 02-09-2006, 11:40 AM   #12
Conspicuous Member
Crocodile's Avatar
15,114, Level: 29
Activity: 13.6%
A lot of current graphics cards/chipsets support different screen orientations natively. As I discovered when I got a call from a friend whose Dell I had recently installed asking why the image was upside down! There were hotkeys enabled & her two year old managed to key the exact combination.
Anyway, back to your question, the mount doesn't swivel but there is a 100mm VESA mounting point if you wanted to do it permanently or search for a 3rd party stand (if such things exist?).
Old 02-09-2006, 3:35 PM   #13
4,207, Level: 15
Points: 4,207, Level: 15 Points: 4,207, Level: 15 Points: 4,207, Level: 15
Thanks: Gave 3, Got 7
Hi. If the screen was to be mounted on the wall via a VESA mount, can the stand be completely removed? The manual isn't very clear. I would hope that the circular base AND the connecting arm would be removable. Is this the case?
Regards FRANC
Old 03-09-2006, 8:24 AM   #14
marekb
Posts: n/a
Thumbs up Re: 19" Widescreen TFT Monitor - £105 Delivered!
Thanks Croc, good spot.
Old 03-09-2006, 8:54 AM   #15
Spy Spy is offline
Spy's Avatar
9,312, Level: 23
Points: 9,312, Level: 23 Points: 9,312, Level: 23 Points: 9,312, Level: 23
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 87, Got 199
Do you think this screen could be used as a TV without a PC ?
If so, what kind of box or unit would need ot be attached to it to receive tv ?
Old 03-09-2006, 11:56 AM   #16
Parmenion's Avatar
5,241, Level: 17
Points: 5,241, Level: 17 Points: 5,241, Level: 17 Points: 5,241, Level: 17
Thanks: Gave 9, Got 19
A Pro V would do the trick
there's one for sale in the classifieds
regards
Parmenion
p.s. my commission is a sticky bun
Old 03-09-2006, 3:37 PM   #17
Conspicuous Member
Crocodile's Avatar
15,114, Level: 29
Activity: 13.6%
Regards FRANC
Yes.
There are a pair of screws either side of the pivot. Removing these allows the stand to be slid out of the housing.
Old 04-09-2006, 8:49 PM   #18
derby4life's Avatar
2,933, Level: 12
the price has gone up to £144 odd now ....just missed out
Old 04-09-2006, 9:05 PM   #19
Conspicuous Member
Crocodile's Avatar
15,114, Level: 29
Activity: 13.6%
Originally Posted by derby4life
....just missed out
I'd have thought a Rams fan would be used to that?
Just keep Googling. This all started with Play offering them & prices have been up & down all over the place. Their current price is £129.99 delivered but it's been common for prices to change 3/4 times a day!
Old 05-09-2006, 5:12 PM   #20
derby4life's Avatar
2,933, Level: 12
none taken
Old 06-09-2006, 9:38 AM   #21
5,172, Level: 17
Points: 5,172, Level: 17 Points: 5,172, Level: 17 Points: 5,172, Level: 17
Thanks: Gave 2, Got 3
Mine arrived yesterday.
First impressions are pretty good, although the stand is made from plastic and looks flimsy (I nearly broke it). I probably will be using a VESA mount so that shouldn't bother me. No dead pixels, and I demoed it with with HD feed and it looked pretty impressive, although there I did notice some ghosting and some colours seemed a little off. I've seen much better, but I've seen worse for more than this price.
One word of caution, buy a DVI cable. I tested it with a VGA and DVI, and there was a noticable difference.
But all in all a pretty decent monitor. I compared it to my £270 20" Samsung 205BW, and although the samsung was much better, the difference was much less than £160...
Thanks OP!
Old 06-09-2006, 12:12 PM   #22
19,160, Level: 33
Points: 19,160, Level: 33 Points: 19,160, Level: 33 Points: 19,160, Level: 33
Thanks: Gave 10, Got 58
Got mine this morning. Only connected it to my laptop to test and I'm impressed. As mentioned the base is pretty flimsy but the picture seems as good as any other budget LCD.
Old 07-09-2006, 2:37 PM   #23
xelallah
Posts: n/a
Damn, missed it, its now not available!
Old 18-09-2006, 8:28 PM   #24
tinners's Avatar
9,287, Level: 23
Points: 9,287, Level: 23 Points: 9,287, Level: 23 Points: 9,287, Level: 23
Thanks: Gave 98, Got 258
£130 at Savastore. Man I'm tempted for the 360.....
Old 21-09-2006, 6:03 PM   #25
forrestgump's Avatar
8,069, Level: 21
Points: 8,069, Level: 21 Points: 8,069, Level: 21 Points: 8,069, Level: 21
Thanks: Gave 117, Got 54
why not just go to pc world and get the HP 19" widescreen monitor for £150.00, was watching hi-def film trailers this aft on mine, awesome.
There is sometimes too much emphasis on the lowest price, how do duracell sell any batteries if this was the case!!
HTML code is On
