LG Hi-Def 42" Plasma for £999.00!!!
Old 15-07-2005, 6:21 AM   #1
forrestgump's Avatar
8,069, Level: 21
Points: 8,069, Level: 21 Points: 8,069, Level: 21 Points: 8,069, Level: 21
Thanks: Gave 117, Got 54
Could be a potential bargain from Aldi as of 21/07/05. Says on the blurb that it is hi-def ready but the wording is a bit ambiguous as it says via DVD input, probably should read via DVI input, have copied spec for anyone interested below:-
Watch all your favourite films and programmes in crystal-clear, panoramic style.
Amazing 10,000:1 contrast ratio
1,500 cd/m2 brightness
Free tilting wall bracket
Fully inclusive 3 year manufacturers warranty worth over £500
HDTV ready
2 x 10W NICAM speakers
Also includes:
42" (106cm) plasma display manufactured by LG in 16:9 format
852 (H) x 480 (V) pixel resolution
Full HDTV compatibility (480p, 720p, 1080i) via DVD input including HDCP decoding.
Over 160º horizontal/vertical viewing angle
16.7 million colours.
Full dual TV tuners manufactured by Samsung for full Picture-in-Picture functionality.
Multi-picture function and full split-screen viewing
99 TV channels
Optimal solution 1280 x 1024 over VGA.
2 x 10W built-in speakers
NICAM Stereo Sound
On-screen display menu
Full Teletext with 100 page memory
Automatic channel search
Sleep timer
Picture freeze function
Size: 1045 x 640 x 88mm (without stand) 1045 x 700x 240mm (with stand)
Approx. weight 50kg
Remote control (batteries included)
Customer helpline available
Three year warranty
Old 15-07-2005, 6:46 AM   #2
40,155, Level: 49
Points: 40,155, Level: 49 Points: 40,155, Level: 49 Points: 40,155, Level: 49
Activity: 12.2%
Activity: 12.2% Activity: 12.2% Activity: 12.2%
Thanks: Gave 1,628, Got 839
It's not a hidef plasma with an 852x480 native resolution!
Old 16-07-2005, 6:55 AM   #3
8,069, Level: 21
that's why I said the wording was a bit ambiguous, it says optimal solution 1280/1024 which if it should be maximum resolution then it will be hi-def, aldi could be in trouble with the trades description act on this one!!!
Old 16-07-2005, 5:50 PM   #4
5,827, Level: 18
Points: 5,827, Level: 18 Points: 5,827, Level: 18 Points: 5,827, Level: 18
Thanks: Gave 18, Got 46
This sounds bargainous, but I've searched but can't find any plasmas with such a high contrast. How do you know it's an LG? Does anyone know where to contact Aldi? I can't find any email address to query them, or phone numbers. It already seems to be a poor place to buy for any support. I can just see the check out girl when you ask any questions. I'm unsure that Aldis stack em high attitude works for plasmas.
Old 16-07-2005, 8:41 PM   #5
3,757, Level: 14
Points: 3,757, Level: 14 Points: 3,757, Level: 14 Points: 3,757, Level: 14
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 21, Got 5
I checked out the Aldi website and their ad for the plasma has an LG badge at the top of it (and Samsung). Like other electrical goods they sell, the set itself will be Tevion badged. Whilst the appearance is different, the spec seems very similar to the LG RZ-42PX11 (see 4 x Forum reviews - guide price £1400) down to the claimed contrast, which one review confirms is exaggerated. The LG has a DVI socket, but the resolution is 852 x 480. However, looking at the mainly positive reviews, if the Aldi offering IS the LG, then with a 3-year warranty, it's a bargain.
Old 21-07-2005, 7:40 AM   #6
11,444, Level: 25
Points: 11,444, Level: 25 Points: 11,444, Level: 25 Points: 11,444, Level: 25
Activity: 12.2%
Thanks: Gave 258, Got 219
Following pressure from AV Forum members Aldi have been forced to remove the HDTV Ready logo from their advertising and website. This set clearly is not. It remains to be seen if it is a bargain or an outdated model being flogged off on the cheap. It appears to be able to accept HD, but downscales it to SD. I guess someone will buy it at that price.
Old 25-07-2005, 6:45 PM   #7
8,069, Level: 21
The Power of the AV Forum members!!!
HTML code is On
