Panny DECT & GAP Phone
Old 19-03-2005, 6:13 PM   #1
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Panny DECT & GAP Phone £19.95
not AV kit but Argos have the Panasonic KXTCD430EB single handset cordless DECT phone for £19.95 BARGAIN!
is GAP compatible so can use an additional handset with existing system and has OK memory et LCD is not Backlight which could be an issue in an HC room and finish ia bit cheap and plastic but a cheap usable phone and sound is fine! but for under £20 great VFM!!!! (looked online and it was £30+)
http://www.argos.co.uk/webapp/wcs/st...&go.x=6&go.y=7
Old 19-03-2005, 8:22 PM   #2
Senior Moderator
Flimber's Avatar
20,339, Level: 34
Points: 20,339, Level: 34 Points: 20,339, Level: 34 Points: 20,339, Level: 34
Activity: 42.0%
Activity: 42.0% Activity: 42.0% Activity: 42.0%
Thanks: Gave 2,924, Got 2,441
Looks good but Ebuyer are doing the 560 (with it's nice base station) for £29.95
Mike.
Old 22-03-2005, 7:27 PM   #3
Assured Advertiser
63,997, Level: 61
http://www.ebuyer.com/customer/produ...duct_uid=78000 £35 delivered but a nicer phone...................
HTML code is On
