Eltax Symphony 6.3 Speakers 170W RMS Max Power Only £39.99!
Old 03-08-2004, 3:42 PM   #1
Aletank's Avatar
3,036, Level: 12
Points: 3,036, Level: 12 Points: 3,036, Level: 12 Points: 3,036, Level: 12
Thanks: Gave 24, Got 1
How about these, Eltax Symphony 6.3 Speakers 170W RMS Max Power Only £39.99!
Maplin have a great bargain on a pair Eltax Symphony floor standing speakers which peak up to 170W RMS! These speakers are powerfull and have great reviews "Although bright, the Symphony 6s score for clarity and power. Bass is fast and accurate."
Only £39.99 including VAT and delivery! RRP around £200.
System: 2 way bass reflex
Long term Max power: 90W
Short term Max power: 170W
Frequency range: +/- 4 dB 35-22,000Hz
Sensitivity: (2,83V / 1M) 89dB
Impedance: 4-8 Ohm
Tweeter: 25mm dome
Woofer: 165mm
Dimensions: (HxWxD) 750x220x250mm
www.maplin.co.uk Add code: L58AY in the search box then hit go.
Old 04-08-2004, 6:52 PM   #2
Solar's Avatar
5,559, Level: 17
Points: 5,559, Level: 17 Points: 5,559, Level: 17 Points: 5,559, Level: 17
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 139, Got 202
those speakers were part of a 5.1 package so dont expect them to be boxed
HTML code is On
