Fuji FinePix M603 + 1GB IBM Microdrive
Old 18-12-2003, 8:07 PM   #1
milgo
Posts: n/a
This sounds like a good offer if you're considering this camera.
http://www.fujioffer.co.uk/
Old 18-12-2003, 8:14 PM   #2
7,188, Level: 20
Points: 7,188, Level: 20 Points: 7,188, Level: 20 Points: 7,188, Level: 20
Thanks: Gave 4, Got 2
I wasn't, but that looks quite good.
Darnit
What about those little drives and their moving parts though...?
Old 19-12-2003, 8:12 PM   #3
rkb rkb is offline
3,694, Level: 14
Points: 3,694, Level: 14 Points: 3,694, Level: 14 Points: 3,694, Level: 14
Thanks: Gave 28, Got 26
don't worry about the microdrive- it's very reliable.
I have a fuji 602 (SLR shape) with microdrive- works fab- stores around 300pics at 3MB resolution or over 1000 at lower res!
When I got the camera about 18months ago, the microdrive retailed at £300 alone, so I waited and bought one this summer from www.scan.co.uk for £120. Don't know if it's fallen any further in price.
BTW,you can use the microdrive to store files for your PC. I use a USB card-reader and by plugging it into the PC and can then write to the new "E" drive (microdrive) then transfer files elsewhere.
Hope that helps!
RKB
Old 20-12-2003, 3:21 AM   #4
7,188, Level: 20
Welcome to the forums, rkb.
Now...
That wasn't the answer I wanted!
Gonna have to take a closer look at the darn thing now...
P.S. Thanks for the good info. Yes, thanks a lot!
Old 20-12-2003, 6:50 AM   #5
milgo
Posts: n/a
Better hurry, only 2 days left now!
Old 20-12-2003, 2:19 PM   #6
Ekko Star's Avatar
17,890, Level: 32
Points: 17,890, Level: 32 Points: 17,890, Level: 32 Points: 17,890, Level: 32
Thanks: Gave 23, Got 202
Yes the microdrives are very reliable and quite robust.
The only thing is they can be quite power consuming, so not sure how long it will last in this particular camera.
Old 23-12-2003, 9:17 AM   #7
Mr Cat's Avatar
16,833, Level: 31
Points: 16,833, Level: 31 Points: 16,833, Level: 31 Points: 16,833, Level: 31
Thanks: Gave 21, Got 66
check out - http://www.photographyblog.com/revie...nepix_m603.php
it got 3 1/2 out of 5...not bad!
but offer ends today...
Old 24-12-2003, 6:21 PM   #8
Ekko Star's Avatar
17,890, Level: 32
https://secure.hitech-uk.com/acatalo...epix_M603.html
if you just want the camera on it's own £199.
+ £98.99 for the IBM kit which includes OEM IBM 1Gb drive (not Hitachi Badged) and PCMCIA Type II converter.
Old 24-12-2003, 8:20 PM   #9
3,048, Level: 12
Points: 3,048, Level: 12 Points: 3,048, Level: 12 Points: 3,048, Level: 12
Thanks: Gave 9, Got 8
Hitachi now owns IBM's hard drive outfits, all the same kit
HTML code is On
