Ink from a £1...
Old 08-12-2003, 11:03 PM   #1
15,820, Level: 30
Points: 15,820, Level: 30 Points: 15,820, Level: 30 Points: 15,820, Level: 30
Thanks: Gave 583, Got 289
Ink from a £1...
http://discandink.co.uk/index1.html
Even chipped Epson carts are £2.50 and that includes p+p.
Old 09-12-2003, 12:28 AM   #2
8,341, Level: 21
Points: 8,341, Level: 21 Points: 8,341, Level: 21 Points: 8,341, Level: 21
Thanks: Gave 3, Got 3
just orderd 3 black and 3 colour for £8.97. Thanks for the link lynx.
Old 26-12-2003, 12:09 AM   #3
pardip
Posts: n/a
Thanks! Just ordered a few cartridges.
Old 30-12-2003, 2:38 PM   #4
seany's Avatar
21,388, Level: 35
Points: 21,388, Level: 35 Points: 21,388, Level: 35 Points: 21,388, Level: 35
Do your own refills and save a fortune http://www.inktecuk.co.uk/inkjetrefills.htm
Old 30-12-2003, 2:54 PM   #5
pardip
Posts: n/a
But £1 for a cartridge is a bargain! Received mine this morning.
Old 30-12-2003, 4:16 PM   #6
15,820, Level: 30
Thats fine if it's an unchipped cart, or you have the software to reset the ink levels in the software ink level monitor.
Old 30-12-2003, 4:25 PM   #7
pardip
Posts: n/a
Yeah.. I have an aging Epson Stylus Color II. I need cheap cost per page as I print hundreds of pages in lecture notes every term!
Old 01-01-2004, 2:03 PM   #8
seany's Avatar
21,388, Level: 35
It gives you a guide, there is a video to. You get the kit to do it
http://www.inktecuk.co.uk/57_58_reset.htm
Old 01-01-2004, 4:57 PM   #9
15,820, Level: 30
It's an Epson i've got.Doesn't appear to be refills for them.
Old 01-01-2004, 5:11 PM   #10
seany's Avatar
21,388, Level: 35
Don't they? Sorry mate
Old 02-01-2004, 2:11 AM   #11
seany's Avatar
21,388, Level: 35
This might do you lynx
http://www.inktecuk.co.uk/inkjet_ink.htm#HewlettPackard
http://www.inktecuk.co.uk/chip_resetter.htm
Old 02-01-2004, 11:57 AM   #12
15,820, Level: 30
Old 02-01-2004, 12:11 PM   #13
seany's Avatar
21,388, Level: 35
Big savings there mate. I can't get a compat cheaper then £16 for my printer. Yet this way i can get 60ml (my colour holds 17ml) for £18
HTML code is On
