Samsung DVD-SR275M @ Currys
Old 03-09-2009, 11:14 AM   #1
1,595, Level: 9
Points: 1,595, Level: 9 Points: 1,595, Level: 9 Points: 1,595, Level: 9
I picked one up yesterday for £2.97
If you are lucky enough to find a store who have them in stock, I know york have 4, they will most likely be ex-display or pre-owned, but for a digital DVD recorder with HDMI, can you complain?
They also have a Samsung BD2 7.1 blu ray cinema system for £19.97!
Old 03-09-2009, 11:34 AM   #2
1,592, Level: 9
Points: 1,592, Level: 9 Points: 1,592, Level: 9 Points: 1,592, Level: 9
Thanks: Gave 3, Got 2
Re: Samsung DVD-SR275M @ Currys
is this straight up and where did u find out about the deal
Old 03-09-2009, 12:00 PM   #3
1,595, Level: 9
I work for them!
Old 03-09-2009, 5:49 PM   #4
1,592, Level: 9
how can someone in the glasgow area get that blu ray system
Old 03-09-2009, 5:53 PM   #5
1,595, Level: 9
Pop into your local branch and ask if any local stores have one!
Old 03-09-2009, 6:55 PM   #6
1,592, Level: 9
can you check on the computer where i could get that blu ray system or have it sent to me
Old 03-09-2009, 6:57 PM   #7
1,595, Level: 9
Unfortunately I'm nt working for the next few days, you wouldn't be able to have one sent, we make -£500 on it as it is!
Sorry
ORTONLEGACY (03-09-2009)
Old 03-09-2009, 7:09 PM   #8
1,592, Level: 9
thanks alot for all your help mate
sorry for all the questions mate
let you know how i get on
i am going to get that blu-ray system tomorrow if there is any left
might get the dvd player tho
thanks very much
one more question do you know the product code or model number of blu-ray system
thanks mate http://www.avforums.com/forums/image...s/thumbsup.gif
