18-02-2008, 4:31 PM
#1 (permalink)
Thanks: Gave 2, Got 0
DVD to Hard drive on dvd recorders ?
I understand that hard drive recorders are designed to record TV...
but can they also store DVDs onto the hard drive too ?
18-02-2008, 4:42 PM
#2 (permalink)
Thanks: Gave 77, Got 756
Re: DVD to Hard drive on dvd recorders ?
If you mean commercially produced DVDs...no.
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
18-02-2008, 4:58 PM
#3 (permalink)
Thanks: Gave 6, Got 462
I believe the Archos units are allowed to store commercial dvds on their hard drives,for you to watch on trips etc  .You cannot copy them to other devices though.
18-02-2008, 5:03 PM
#4 (permalink)
ok how about Divx movies or mpegs or DVDs which are not commercially produced ?
18-02-2008, 5:13 PM
#5 (permalink)
no idea about divx,never used the format,but mpegs from the web or a digi camera,then yeah you can put them on a hdd.
18-02-2008, 5:17 PM
#6 (permalink)
Thats cool...I have a lot of backed up DVDs created using DVDshrink would they work ?
I guess i'm really lazy  i just want to be able to watch any dvd i want without having to get out of bed and take them out of the tray etc lol
18-02-2008, 5:21 PM
#7 (permalink)
well if you have finalised the discs then it should work,beware if you havent coz they will only work on the machine they were burnt on,well in my case annyhoo!
18-02-2008, 5:31 PM
#8 (permalink)
your probably not allowed to discuss dvd shrink on here,but like i said the archos units do what you require and are legal in that regard.
18-02-2008, 6:08 PM
#9 (permalink)
Thanks: Gave 70, Got 1,088
It is usually possible to PLAY DivX discs on machines that support DivX ... but not possible to move them to the hard drive.
Ask yourself : " WHY do I believe what I believe?"
My opinions expressed here are not representative of the opinions of AV Forums.
18-02-2008, 10:03 PM
#10 (permalink)
I guess i'll just need to get an imac then...i believe they have remote controls for menu/dvd operation
19-02-2008, 10:05 AM
#11 (permalink)
Thanks: Gave 6, Got 126
If it's capable of transferring home DVDs (ie. camcorder or PC edited) then it's just as likely to work with any DVD that DOESN'T have copy-protection on it. DVDs WRITTEN on your home PC  CANNOT have copy protection on them.
19-02-2008, 3:05 PM
#12 (permalink)
So can anyone confirm that they have successfully stored their dvds on the hard drive even tho its not supposed to be for that purpose ?
26-02-2008, 2:01 PM
#13 (permalink)
In case anyone's interested....a dvd/freeview player with USB port + external hard drive should do it
26-02-2008, 2:22 PM
#14 (permalink)
Thanks: Gave 1, Got 9
On Panasonic EX77 as long as the DVD is not copy protected you can. I tried this with an old Sherlock Holmes DVD and it copied over no probs (well the few minutes I tried). You would have to copy over in real time. Alright as long as you don't want to use the machine to record TV as the DVDs would take up a whole lot of space. I also had the option of recording in different quality modes so that would be an option of streatching out how many DVDs you could get on the hard disk.
27-02-2008, 8:37 AM
#15 (permalink)
Thanks for that info Bigalt, i plan on getting myself a fairly cheap dvd/freeview player (not worried about recording TV really as most of its crap anyway!) with a USB port plus a 160-250GB portable hard drive..then via my PC i can back up my dvds and possibly convert to divx/mpeg that way i'll be able to get a substantial amount of DVDs viewable from my bed !
