Lg Rh188s
Hello!
I have my LG for over one year and so far I'm very satisfied with it.
I only had problems with couple of movies in divx format.
problem no1.
divx cartoon playable on my computer, in resolution which (according to manual) must be played, but it doesn't... when I press play it goes for two seconds and then I have message "can't playable"
problem no2.
divx movie - works fine on computer, when played in recorder I have only sound, no picture and can't do anything - stop doesn't work, eject, nothing. I have to switch it off manualy - and all the time (before pressing off on console) sound was working..
problem no3 - similar to no1
movie in divx, works great on computer, resolution ok, starts in recorder with weird distorted sound, picture great and after 5 seconds it says "can't playable". I can fast forward it, but when I press play, after 5 seconds "can't playable" and before that distorted sound. On computer sound and picture are ok.
Today I upgraded my firmware from 60807A to 60911A but problems stays the same - didn't notice any improvements.
help please!
