AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 17-02-2008, 11:57 AM   #1 (permalink)
Thanks: Gave 6, Got 3
Advice Please
Hi all,
please be patient in reading this from a newbie!
have bought a Panny eb27 dvd recorder after reading reviews and was hoping someone can assist me. The recorder has an optical out to my amp which has an optical in in socket as well as coaxial. Bought the recorder from digital direct for £123 compared to £180 at local shop Curry's. Went into Curry's for a look at the recorder and on examining the rear of the machine found that the optical out slot covered by plastic fitment:
Q1 does this fitment peel off so I can insert the cable ?
Q2 please advise on the cable required, will a tos link optical cable suffice ?
Thanks for reading
dmax
dmax66 is offline   Reply With Quote
Old 17-02-2008, 12:13 PM   #2 (permalink)
Thanks: Gave 70, Got 1,088
Re: Advice Please
Originally Posted by dmax66 View Post
Hi all,
Thanks for reading
dmax
Welcome to the forum.
Q1 - The socket is usually protected with a small plastic plug- It simply pulls out - yes.
Q2 - Yes - Standard Toslink cable is the one to use.
Good luck.
Ask yourself : " WHY do I believe what I believe?"
My opinions expressed here are not representative of the opinions of AV Forums.
Gavtech is online now   Reply With Quote
Old 17-02-2008, 12:16 PM   #3 (permalink)
Re: Advice Please
Thanks Gavtech, apologies to all but have recognised that there is a forum especially for cables/ interconnects.
dmax
Old 17-02-2008, 12:24 PM   #4 (permalink)
Re: Advice Please
dmax
No problem- This is still a DVDR issue.
Good luck with your purchase.
Old 17-02-2008, 12:47 PM   #5 (permalink)
Re: Advice Please
Should I be aware of different jack sizes ?
Thanks.
Old 17-02-2008, 12:51 PM   #6 (permalink)
Re: Advice Please
Thanks.
Standard Toslink will be the size... Just avoid mini-toslink.
See this for more info:
http://en.wikipedia.org/wiki/Toslink
dmax66 (17-02-2008)
advice
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Looks like I need some good upgrade advice....due 2 advice on speaker forum Please :) nero0410 Integrated AV Amplifiers and Receivers 16 15-01-2008 6:14 PM
Advice: simple to use MP3 player advice? (also suggestion for speaker/DAB options) Dystran Portable Music (MP3, iPod etc.) 0 12-01-2008 9:31 AM
Advice on balancing system -AV receiver advice GarethG Integrated AV Amplifiers and Receivers 6 13-11-2007 10:32 PM
1st time HTPC Case advice and general advice s.t.s Home Cinema PCs 30 31-05-2007 10:36 PM
Revo DAB radio install advice - power advice needed (please) wydcus In Car Entertainment (ICE) 3 16-10-2006 8:43 AM
AV ForumsOptimised for Firefox.
