AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 01-11-2007, 9:32 AM   #1 (permalink)
Thanks: Gave 22, Got 4
Pioneer DVR-550HX-S - where can I find reviews?
hi
i'm looking at buying Pioneer DVR-550HX-S and was wondering if anyone can point me in the direction of some reviews.
I tried googling but cant find any
bharatgi is offline   Reply With Quote
Old 01-11-2007, 9:53 AM   #2 (permalink)
Thanks: Gave 70, Got 1,088
Re: Pioneer DVR-550HX-S - where can I find reviews?
http://www.pioneer.co.uk/uk/products...X-S/index.html
PDF manaul available on this page:
http://www.superfi.co.uk/index.cfm/p...roduct_ID/3374
I doubt the single point this reviewer makes is accurate. Probably a case of not knowing how to achieve it.
http://www.mrmdvd.com/catalog/produc...93fa196cc70f0a
Ask yourself : " WHY do I believe what I believe?"
My opinions expressed here are not representative of the opinions of AV Forums.
Gavtech is online now   Reply With Quote
Old 01-11-2007, 1:05 PM   #3 (permalink)
is there no offical reviews from magazines?
Old 01-11-2007, 1:14 PM   #4 (permalink)
I looked, but couldn't find one... but in any case those magazine appraisals should always be treated with suspicion.
They can be useful at pointing out specific operational issues - but that's all.
So is there some specific function you want... because otherwise it is a Pioneer and that means excellent build quality and will be a good machine.
Old 01-11-2007, 3:13 PM   #5 (permalink)
No, there is no specific function i want to use apart from transferring programs from my sky hd box, making the odd dvd and connecting the recorder to my LX50 amp for surround sound.
i know the programs from my Sky HD box will be in SD format once transferred as i can only use the scart to connect the two devices.
Overall, i like the Pioneer DVR-550HX-S a lot because it can read/write most DVD Formats but i just found it strange there was no magazine reviews on the net.
Old 01-11-2007, 6:07 PM   #6 (permalink)
Thanks: Gave 0, Got 8
Certainly I do not recommend DVR-550HX-S in your case, but DVR-LX60D, as it fits in design to your LX60 receiver. No doubts, the only choice.
If you still insist not to match design, there is a later model DVR-555HX-S, supporting reomote over HDMI and USB port.
Sony is known for its grainy picture and Panasonic is the only other left from the better devices including DVB-T tuner. Beware of the Pioneer, as it use to have noisy drives. Some people found it as a reson to replace them. In my PC I got Pioneer recorder, it works perfect, but is a bit noisy, like a cricket, compared to my NEC which is almost noiseless.
javelin_ is offline   Reply With Quote
Old 02-11-2007, 10:17 AM   #7 (permalink)
i am not bothered about the colour of the recorder and dont really want to spend almost £500 on a DVD recorder.
Whilst the later model DVR-555HX-S, supports remote over HDMI and USB port seen as its not available in the UK i think i'll buy the DVR-550HX-S.
But thanks for telling me about the noise problem.
Old 26-02-2008, 7:42 PM   #8 (permalink)
ThunderBoltLSD's Avatar
Thanks: Gave 5, Got 3
That's got to be the best review I've ever seen!
ThunderBoltLSD is offline   Reply With Quote
dvr550hxs, find, pioneer, reviews
Refbacks are On
AV ForumsOptimised for Firefox.
