AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 31-10-2007, 1:48 AM   #1 (permalink)
Thanks: Gave 6, Got 4
Progressive scan
Is this the same as upscaling?
Gawaine is offline   Reply With Quote
Old 31-10-2007, 8:20 AM   #2 (permalink)
Thanks: Gave 128, Got 232
Re: Progressive scan
No.
"Normal" TV pictures are interlaced - the odd lines are shown first, 1, 3, 5 etc then the even lines 2, 4, 6. This leads to flicker.
DVDs of films are encoded differently often using a technique called 3:2 pulldown. If yourr DVD player and TV both support it, the DVD player can output the film progressively, line 1 then line 2, then line 3 etc. Less flicker, better picture, but still the same number of lines overall.
Upscaling is where the source is, say, 576 lines and your screen has, say, 768 lines. Somewhere extra lines have to be added in otherwise the picture wouldn't fit. This is upscaling and can be done by the source (Sky HD box, DVD player) screen or a separate box in between like a Lumagen or an AV receiver.
Don't forget that:
1/ If your TV panels's native resolution is greater than 576 lines it will have an upscaler built in.
2/ The black lines top and bottom when watching films are because the film is in letterbox format not because its not upscaled properly.
All that is necessary for the triumph of evil is that good men do nothing. attributed to Edmund Burke.
Philips 37PF9830, Denon AVR4306, Panasonic NV-HD660B, Philips N1700, Xbox360, Technics SP25, Sony CDP-CX450, Sony CDP-CX455, SkyHD, Nokia N95 8GB
andykn is offline   Reply With Quote
progressive, scan
Refbacks are On
AV ForumsOptimised for Firefox.
