AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 30-10-2007, 11:11 PM   #1 (permalink)
Thanks: Gave 1, Got 1
Changing hard drive on Panasonic EH67
1. Would it be possible to upgrade the 250GB hdd on Panasonic EH67 to a larger drive (320,400,500GB) or does the electronic circuitry or firmware on the recorder limit it to 250GB?
2. What filesystem do hdd use on Panasonic recorders? Are they standard Win systems like FAT32 or NTFS or do they use a Panasonic-specific filesystem?
Thanx
okiz
okiz is offline
Old 30-10-2007, 11:28 PM   #2 (permalink)
Thanks: Gave 65, Got 1,007
Re: Changing hard drive on Panasonic EH67
Thanx
okiz
Forget it.
Panasonic have made upgrade virtually impossible. Only the specified original size will ever be seen irrespective of disc capacity.
Windows will not recognise the filesystem ... and even if you can get past that , they use a proprietary encoding format.
Ask yourself : " WHY do I believe what I believe?"
My opinions expressed here are not representative of the opinions of AV Forums.
Gavtech is offline
Old 31-10-2007, 12:02 AM   #3 (permalink)
Thanx, Gavtech.
okiz is offline
Old 05-11-2007, 3:08 PM   #4 (permalink)
Thanks: Gave 7, Got 3
well on my eh50 with 80gb i tried to swap the hdd for a 500gb one,it worked fine but was still showing 80gb after i formatted it so its either firmware locked or electronically which is a bit sucky tbh but was worth a try i guess
Sony KDL-40D3000 ,Panasonic Eh50 ,Sony Vaio VGXl-100 ,Sky Digital
Snakey2k5 is offline
Old 05-11-2007, 4:51 PM   #5 (permalink)
Thanks: Gave 4, Got 8
Out of interest, what make was the hard disk in the '67? The fact that companies go out of their way to disguise the brand and model is why I skipped it this time around.
Had I known it was Western Digital, the brand I know to be the most reliable in the past ten years in my PCs, I'd have found the extra £50 for the 'EZ77. But if it's ultra-cheap Excelstor, then I don't need a timebomb in with my recorder thanks very much.
NethLyn is offline
changing, drive, eh67, hard, panasonic
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
