AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 05-04-2007, 11:10 AM   #1 (permalink)
Thanks: Gave 4, Got 2
toshiba hard drive recorder rgb issues
friends have just bought a 26" Samsung LCD tv (LE26R7) and a Toshiba dvd recorder (RD-XS25SB) and are having some problems and i cant figure out why!
when the dvd recorder is played back (or recorded or tv is watched via) the AV1 (rgb) scart socket then there are a couple of flashes to a black screen (it varies from 2 to 4 and the sound cuts out too) every few mins... but if connected via AV2 (non rgb) then it doesnt do it...
ive checked all the settings (i think) and everyting is correct as far as i can tell so i have no idea why its doing it... its obviously some kind of rgb conflict and must be to do with the toshiba dvd recorder as when it is off or freeview is watch directly thru the tv then all is fine...
has anyone experienced this before?
bunyboy is offline   Reply With Quote
Old 05-04-2007, 1:46 PM   #2 (permalink)
Thanks: Gave 70, Got 1,088
Re: toshiba hard drive recorder rgb issues
I suggest trying the DVDR with another RGB-in-capable TV to see if the effect is still present... to determine for sure whether it is an issue of the DVDR or the TV.
Ask yourself : " WHY do I believe what I believe?"
My opinions expressed here are not representative of the opinions of AV Forums.
Gavtech is offline   Reply With Quote
Old 05-04-2007, 2:42 PM   #3 (permalink)
i wish that was possible but they only have one other tv.. a small portable with no rgb scart...
are you suggesting that one or other is faulty? i was thinking it was a settings or maybe a cheap scart lead issue or something... they wont like the idea of sending it back at all!
Old 05-04-2007, 3:22 PM   #4 (permalink)
What about another device with an RGB output - so at least you could see if the TV performed OK with that?
Yes I was suggesting that. It is possible.. and if so it would be nice to isolate which was the culprit.
RGB is just analogue and fairly unsophisticated so one would not expect any major conflicts between devices.
The fault description does give the impression of two different sync signals beating with each other.
The DVDR is not set to output NTSC perhaps?
A good scart lead is certainly worth trying. [ Must be fully wired and much preferred with individual core screening ]
Hopefully it would sort your problems... but if not and they have just obtained these units ... I cant help thinking that the problem should be thrown back at the retailer.
drive, hard, issues, recorder, rgb, toshiba
Refbacks are On
AV ForumsOptimised for Firefox.
