Originally Posted by johnslad
First posting. DMR-EH50 about 10 months old. Was finalising disks ok until recently. Now only finalises occasionally and often with a great deal of noise. Started with TDK x8 & Arita x8 DVD-R disks and all were ok. Changed to Philips x16 then trouble started. Was that just coincidence? Changed again to RiData x8 but problem persists. Is it just a problem with the disks or something more serious?
Welcome to the forum johnslad.
It is nearly always Disk problems.
Try Taiyo Yuden disks... I think it very likely you will find that all your troubles disapppear.
A cleaning disk would not do any harm either.
Have a look at:
http://svp.co.uk/
... and put Taiyo Yuden in their search box near the top of the page.
That should present a variety of disks that use the TY dye ... Taiyo Yuden sell under their own brand name as well as Panasonic, Verbatim etc. .
The thing to be aware of is that disks brands can use many types of dye and change often .. so it is no good going by brand name alone. Always check out the dyemaker.
For example , Verbatim use other dye makers too.
