Ok, really sorry for my ignorance on this one but...........
My mam got an LG recorder (LG RH177) for christmas with built in hard drive. Now she can record both from her normal TV channels and her freeview box by just hitting record and it records whatever is on the screen on the DVD channel but we are having real problems when it comes to setting the timer for recording from freeview.
It will only record whatever freeview channel you leave the box set on, I was under the impression that you could program each station into the recorder and then record as required. But as I tried to store the freeview channels it just sees the whole freeview signal as one channel, hence it records only what the set top box is on.
I am choosing decoder when trying to set up the freeview channles.
Any help would be greatfully received as I am totally stumped on this,
