AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 10-01-2007, 7:44 PM   #1 (permalink)
Thanks: Gave 9, Got 18
Smile DVD Recorder under £300.00 Please
Having just purchased the Fantastic Panasonic 42PX60 I would now like a decent DVD Recorder to match. Ideally costing no more than £300.00. The Panasonic DMR EX75 sounds great, but would the integrated freeview be a bit of a waste ? Thanks in advance for any advice.
bigbaz is offline   Reply With Quote
Old 10-01-2007, 9:45 PM   #2 (permalink)
bob1's Avatar
Thanks: Gave 15, Got 73
Re: DVD Recorder under £300.00 Please
Why would the integrated freeview be a bit of a waste, i would have thought it would be usefull ,it would mean that you could record one channel while watching another.
Panasonic TH-42PWD8BS plamsa,Oppo 971h dvd,Targa DRH-5100x dvd/hdd pvr,Humax pvr-9200t freeview pvr, Dreambox Dm7000s satellite pvr ,Yamaha DSP-AX763av amp, Canton cd100, cd50,cd10 speakers
, Svs Sb12+ sub woofer
bob1 is offline   Reply With Quote
Old 11-01-2007, 6:44 PM   #3 (permalink)
Question Re: DVD Recorder under £300.00 Please
Thanks Bob1 for the reply, I just assumed that with my TV (PX60 integrated freeview) I would not require F/V in a DVD Recorder. Am I wrong ? If having F/V in both TV and DVD is an advantage, would you recommend a DVD REC to me.
Old 11-01-2007, 8:53 PM   #4 (permalink)
bob1's Avatar
If your going to put stuff onto dvd then yes it will be worth it ,if your only going to record the odd tv program you might as well look at getting a pvr,it all depends on what you want to do.
dvd, recorder
Refbacks are On
AV ForumsOptimised for Firefox.
