AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 04-01-2007, 7:33 PM   #1 (permalink)
Record From Built in freeview?
Can you record freeview from a tv with built in freeview to a hdd dvd recorder?
When tuning the recorder in it only finds the restrial channels.
I have tried different ways of pluging it in but no luck.
Thank you.
biqfish is offline   Reply With Quote
Old 04-01-2007, 8:02 PM   #2 (permalink)
TOM ALLEN's Avatar
Location: EUROPEAN CAPITAL OF CULTURE - LIVERPOOL (THE WORLD IN ONE CITY)
Thanks: Gave 0, Got 7
Re: Record From Built in freeview?
Hi mate, you need to read the tv manual, somewhere in there it will tell you how to record/output to a recording device. You will find it has a timer just like the vcr, set the time,date & programme/channel number, once this has been done you need to do the timer on your recording device. Now, you will have your lead from tv to recorder, change the channel number on the recorder to whatever the input is, i.e. av 1, av 2 etc.this should now work ok........unless your tv has 2 digital tuners you'll have watch tv thro' the analogue tuner.
I hope I've explained this ok, good luck and
Sagem 45 G4 DLP, V+, Yamaha DSP-AX761, Toshiba E-1
Peekton Divx Player, Rega Planar 3, Yamaha NS-45E Floorstanders, Mordaunt Short Rears, Paradigm Servo 15
Cambridge Audio C3 CD Player circa 1990 sounds great
TOM ALLEN is offline   Reply With Quote
Old 04-01-2007, 8:17 PM   #3 (permalink)
Thanks you for your reply,
i wil give it a go
Old 05-01-2007, 10:15 AM   #4 (permalink)
zappo's Avatar
Thanks: Gave 7, Got 29
We were all newbies once, some people have trouble with manuals through disability or simply because they are badly written.
You could say RTFM to any question, it would not be helpful or constructive.
There are no dumb questions on this forum.
zappo is offline   Reply With Quote
Old 05-01-2007, 12:48 PM   #5 (permalink)
TOM ALLEN's Avatar
Now then Zappo, are you therefore saying I haven't been helpful or constructive, I tried to explain as best I could. The initial reference to the reading the manual was simply because every manufacturer and or model, will be different, and so I couldn't be more precise. My second reference to read the manual, was purely light hearted and I wished him good luck with a smile.
Apologies if I've upset anyone
Old 05-01-2007, 12:59 PM   #6 (permalink)
Knyght_byte's Avatar
Thanks: Gave 84, Got 493
ok guys, play nicely
lets stay with the topic
HC: Infocus 7205, Denon 3803/3910. MA Silver S6, SFX, S2, SLCR. SVS PB12/Plus. Sky+.
Hifi: Musical Fidelity A5, Denon 3910 CD/SACD/DVD-A. Monitor Audio GR10's.
PC: E6700, Gigabyte DS3 965P, 2Gb Corsair, Gainward 8800GTS 640Mb, CL X-Fi Fatal1ty, Jeantech 600w, Antec Sonata II.
Knyght_byte is offline   Reply With Quote
Old 05-01-2007, 4:15 PM   #7 (permalink)
Thanks: Gave 2, Got 238
You cannot download the freeview channels from your idtv into the tuner of an analogue only dvd recorder. You can record from one of the TV's digital freeview channels but this means that you cannot then watch another freeview programme on the TV whilst the recording is taking place.
The best and easiest solution is to connect a freeview STB (any cheap one will do), to the AV2 input scart on your dvd recorder. Select AV2 as the recording source, having first set the freeview channel you require on the STB, and away you go. This leaves you to watch any other freeview channel using the TV's own tuner.
Note : some dvd recorders with smartlink or equiv have the ability to control the STB for dvd recordings.
ROYOLD is offline   Reply With Quote
Old 05-01-2007, 4:32 PM   #8 (permalink)
Thanks: Gave 13, Got 491
Yes, but that's like saying "You cannot watch one Sky channel while sending another Sky channel to your DVD recorder via a Sky box." Surely one of the reasons for buying an idTV is to save having to buy a separate Freeview box - that's certainly why I bought an LCD with built in Freeview. If I was going to go out and buy a Freeview box anyway, I wouldn't have bought an idTV with Freeview built-in. While recording one of the Freeview channels via a scart socket on the TV, the OP can still watch an analogue terrestrial channel, a video or a DVD (if he/she has a DVD player as well as a DVD recorder). Let's face it, it's not often that there are two freeview only channels transmitting something that you would want to watch at the same time anyway.
Broadz is offline   Reply With Quote
Old 06-01-2007, 12:15 PM   #9 (permalink)
Not true. I often record two freeview channels on my PVR's and watch another freeview channel at the same time. Normally prime times between 8 pm to 10pm.
Nor do I consider that I am the only person that does this. Sales of twin tuner PVR's are increasing and the main reason is that they will record two freeview channels simultaneously.
built, freeview, record
Refbacks are On
AV ForumsOptimised for Firefox.
