AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 13-05-2006, 10:31 AM   #1 (permalink)
Thanks: Gave 3, Got 0
Micro sized recorder DVD/HD?
I'm looking for a recorder to add to a LCD (with in-built freeview). Ideally it should also play DVDs. BUT it must be as small a unit as possible. I'm setting up a discrete, wall mounted LCD and want to minimise the clutter around it. Is there anyone that makes a tiny, "micro"-sized unit? Perhaps something that will sit discretely on a shelf next to the LCD?
Cheers for your help!
Paul
paulb33 is offline   Reply With Quote
Old 13-05-2006, 7:26 PM   #2 (permalink)
JayCee's Avatar
Thanks: Gave 77, Got 756
Paul
I don't think such a small DVDR exists at present.
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
JayCee is offline   Reply With Quote
Old 13-05-2006, 8:11 PM   #3 (permalink)
RMCF's Avatar
Thanks: Gave 148, Got 141
The smallest DVD recorder I have ever seen is the Liteon 1105HC.
Its about the size of an A4 sheet of paper.
If you are anywhere near a Currys you can see it in the flesh.
Or check out:
http://images-eu.amazon.com/images/P...2.LZZZZZZZ.jpg
RMCF is offline   Reply With Quote
Old 13-05-2006, 8:26 PM   #4 (permalink)
ash
ash's Avatar
Thanks: Gave 564, Got 401
You want freeview?
Check out this thread: DVD Recorders with Freeview
I listed as many DVD Recorders with Freeview tuners, fell free to add more. Most of them are the same size. I would reccomend the Pansonic DMRES20/25.
Batman Begins at IMAX!
ash is offline   Reply With Quote
Old 14-05-2006, 7:01 PM   #5 (permalink)
JayCee's Avatar
Yes but the OP has asked for recomendations of micro-sized DVDRs and none of these can be classed as anywhere near that.
JayCee
Old 14-05-2006, 8:07 PM   #6 (permalink)
ash
ash's Avatar
I think he wants freeview with it, or did he mean the LCD has freeview?
dvd or hd, micro, recorder, sized
Refbacks are On
AV ForumsOptimised for Firefox.
