AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 03-03-2006, 12:04 PM   #1 (permalink)
Thanks: Gave 16, Got 22
Sony RDR HXD-910 Fan Always Running
Chaps,
A mate of mine has bought a Sony RDR HXD-910 and is very pleased with it...except that the cooling fan keeps running all the time.
Is this a known problem with this model?
He's now on his second one, but it's just as bad as the first. Even after being on standby for 12hrs or so, the cooling fan is still running!
Is there some sort of menu option to turn it off?
Any suggestions?
dK
Gamertag: daKlone -- Sony KDFE50A12, Denon DVD-1920, Denon AVR-1906, KEF KHT1005, SkyHD, Modded XBOX, XBOX360, Wii, PS3 60GB, iPhone 3G 8GB.
daKlone is offline   Reply With Quote
Old 03-03-2006, 1:54 PM   #2 (permalink)
ArtS's Avatar
Thanks: Gave 1, Got 0
This is not normal. This recorder is fault.
ArtS
ArtS is offline   Reply With Quote
Old 03-03-2006, 2:02 PM   #3 (permalink)
That's what I said - but 2 in a row with the same fault?
Seems unlikely, especially if no-one else has encountered this fault?
dK
Old 03-03-2006, 2:57 PM   #4 (permalink)
Thanks: Gave 17, Got 28
Well, not necessarily faulty.
In the words of Basil Fawlty - to risk stating the b......g obvious - the fan will run all the time if the recorder is running hot all the time.
My 710's fan is on much of the time because it sits at the top of a stack of other AV gear and it all tends to get a bit hot. At the bottom of the stack is a Denon Amp which is making a big contribution to global warming all on its own.
Luckily I sit quite a way from the kit and am not aware of it unless I go close.
philipb is offline   Reply With Quote
Old 03-03-2006, 3:26 PM   #5 (permalink)
But I can't think of any reason it should be hot enough to warrant the fan running when it's been in sandby for several hours, can you?
He hasn't got any other AV kit, so it's not in a stack of equipment or anything.
He's going to have a look at it with a temperature probe, to find out how hot the exhaust air is and if there are any "hotspots" around the case.
dK
Old 03-03-2006, 4:29 PM   #6 (permalink)
I've had one for three months - and have NOT had any problems with this at all. Has he got it well ventilated at the rear of the unit - i checked mine after 24hrs solid running and hardly any heat build up at back was observable.
It's a cracking piece of kit and I can't recommend it highly enough - the PQ is just fantastic
mark....
lazyhazysparky is offline   Reply With Quote
Old 03-03-2006, 4:31 PM   #7 (permalink)
Cheers Mark - what sort of fan action do you get from yours?
dK
Old 03-03-2006, 6:43 PM   #8 (permalink)
Sorry - thought he meant the fan came on when the box came on after standby. If the fan is running when its in standby its definitely faulty.
Old 03-03-2006, 7:00 PM   #9 (permalink)
Right, I'll get him to send this one back too
dK
Old 04-03-2006, 2:17 PM   #10 (permalink)
Thanks: Gave 1, Got 3
This is a hard drive recorder. Are you sure thay what he is hearing is not just the hard drive?
chipray is offline   Reply With Quote
Old 04-03-2006, 3:57 PM   #11 (permalink)
Thanks: Gave 39, Got 31
Just to clarify, the recorder isn't waiting for a timer recording to start, is it?
RunDMC is offline   Reply With Quote
Old 04-03-2006, 5:19 PM   #12 (permalink)
smallmanongn
Posts: n/a
My fan runs early in the morning when the machine isn't even on.
I know that is does it from approximately 4am till about 7am,dont know why but it has always done it.
Maybe it is defragmenting the hard disc or something,who knows.
When I am using it with the TV on you can't even hear it running.
Mine 910 is turned on now and the fan is going,the fan on my old Sony GX3 also used to go all the time but again it wasn't audible in normal conditions.
Old 04-03-2006, 5:33 PM   #13 (permalink)
I noticed my 910's fan was on one morning (about 6.30), in standby mode, had me puzzled, I thought it was recording at first 'til I checked it. I haven't noticed it do it since.
Zappaman is offline   Reply With Quote
Old 04-03-2006, 5:35 PM   #14 (permalink)
Nope.
dK
Old 04-03-2006, 5:35 PM   #15 (permalink)
I don't think so, and there is air being expelled from the fan.
dK
fan, hxd910, rdr, running, sony
Refbacks are On
AV ForumsOptimised for Firefox.
