You can not compare a SKY+ box with a DVD recorder.
Sky+ is a PVR or as close to a PVR that Sky can get to, iut have a twin tuner, which means you can record one channel while watching the other or record two channels while watching something from the hard drive. You can not do that with a DVD recorder, even with the ones with a built in Hard drive.
Some DVD recorders uses Guide plus, which allows the recorder to change the channels on a Sky box, but the Sky box must be out of standby.
I have got a Pioneer DVR-530H-S, which is a great machine, it have got guide plus and a nice big 160GB hard drive.
The main reason why I will not get a SKy + box is because I do not see why I should have to pay an extra £10 a month just to record and also if I decided to drop Sky, then I have got a box, which is more or less useless.
At least with the DVD recorder, I can use it to record from the Freeview box as well.
As for which is the best one to get, well it depends what you want it to do.
