AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 09-07-2005, 7:28 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Panasonic DMR-HS2 to PC?
Hi. I have a Panasonic DMR-HS2 and would like to transfer some of the files from the built-in hard disk to my pc. I've noticed that the recorder and a firewire connection and so is it possible to transfer files on the hard drive over firewire? I know that the connection is only an input but I read somewhere a few months back that it's possible to do. Have any of you tried doing this?
James Coster
JCoster is offline   Reply With Quote
Old 09-07-2005, 7:36 PM   #2 (permalink)
Rasczak's Avatar
Thanks: Gave 420, Got 533
You cannot use Firewire to transfer the files I'm afraid - it's an input only - you should use DVD-RAM (if you have a compatible drive) or DVD-R to transfer the files. Refer to the 'DVD-RAM to DVD-R' link in my signature for guidance!
PC and Console Gamer: Steam (Rasczak) - Live! (Rasczak UK) - PSN (Rasczak) - PC Gaming - The Piracy Issue
Rasczak is offline   Reply With Quote
dmrhs2, panasonic
Refbacks are On
AV ForumsOptimised for Firefox.
