Hi I was wondering did anyone have a fault on their Pan e20 concerning the scarts. At the moment I have no output or input from either AV1. AV2 the s-socket is OK and could anyone enlighting me on what the fault could be and is it easy to fix. I checked the settings on the internal menu and its OK
What are you trying to fed the E20? You should connect your input (assuming it is S-Video or Video) to AV2 and the have AV1 going to your TV. Note the E20 has no RGB input.
__________________ PC and Console Gamer: Steam (Rasczak) - Live! (Rasczak UK) - PSN (Rasczak) - PC Gaming - The Piracy Issue
Thanks for responding I normal use the AV1 and AV2 to either connect to tv or my VCR's and have never used it to fed the E20. I just tried to put an input in when I found that I have no output from the scarts . Thank you
UPDATE! for some unknown reason the scarts are working again, beats me as I don't know what happened but they where not working without doubt as I tried connecting to TV and different VCRs. Will let you know if I work it out or it happens again. Thanks
