AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 08-02-2005, 3:52 PM   #1 (permalink)
Suki G
Posts: n/a
Panasonic DMRE65EBS v DMRE55
how much better is the 65? worth digging a bit more into my pockets for?
also, does anyone know if the 'EBS' is applicable will all models or are theri different suffixes available???
thanks, S.
Old 08-02-2005, 4:08 PM   #2 (permalink)
redsox_mark's Avatar
Thanks: Gave 90, Got 749
I don't believe there is any difference in quality of the recorder.
The difference is in connectivity: the 65 has DV in (useful if you have a Digital camcorder), it also has a SD card slot, useful if you have a digital camera.
The EBS (on both models) is part of the full model name of the UK model.
Mark
redsox_mark is offline   Reply With Quote
Old 08-02-2005, 4:23 PM   #3 (permalink)
Suki G
Posts: n/a
perfect, thanks redsox
Old 08-02-2005, 4:43 PM   #4 (permalink)
Rasczak's Avatar
Thanks: Gave 420, Got 533
The E65 also has a Divide function (E55 can only do this via Playlists), LPCM recording and JPEG compatibility (on DVD-RAM or PC/SD Card slots).
PC and Console Gamer: Steam (Rasczak) - Live! (Rasczak UK) - PSN (Rasczak) - PC Gaming - The Piracy Issue
Rasczak is offline   Reply With Quote
Old 09-02-2005, 9:12 AM   #5 (permalink)
Thanks: Gave 3, Got 1
....and is only £20 more at Richersounds.co.uk
ColonelK is offline   Reply With Quote
dmre55, dmre65ebs, panasonic
Refbacks are On
AV ForumsOptimised for Firefox.
